[Mapserver-users] Warning: [MapServer Error]: msEvalRegex():
kallwn kallwn at icircus.net
Wed Apr 7 16:19:22 EDT 2004
Had a problem that generated almost the same error message. After beating my
head against the wall for about 4 hours and after trying every thing I could
think of I noticed that the editor I was using was saving the extension of
.map in upper case (mymap.MAP). I changed it to lower case and every thing
worked perfectly.
----- Original Message -----
To: <gbustamante at 066sonora.gob.mx>
Cc: "Mapserver List" <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, April 07, 2004 12:45 PM
Subject: Re: [Mapserver-users] Warning: [MapServer Error]: msEvalRegex():
> You should post your map file: mapa.map and we'll take a look.
> On Wed, 2004-04-07 at 15:19, Ing. Guillermo Bustamante wrote:
> > this is not and advance cuestion its kind f introduction one!!!!
> > Im having this error and i dont know how to go further please help me
with this !!!!
> > i need to start a app by the weekend and need to solve this, could
someone helkp me !!!
> > This is the second time that i post this and doesnt seem to appear in
the list.
> > Mexico
> > Warning: [MapServer Error]: msEvalRegex(): String (mapa.MAP) failed
expression test. in /home/test_mapa.php on line 4
> > Warning: Failed to open map file mapa.MAP in /home/test_mapa.php on line
4
> > Fatal error: Call to a member function on a non-object in
/home/test_mapa.php on line 5
> > ___________________________________
> > NOCC, http://nocc.sourceforge.net
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
