[Mapserver-users] Problems with queryMap and style = hilite
Lowell Filak
lfilak at medinaco.org
Wed Apr 7 16:51:25 EDT 2004
After some investigation in the source code - I'm not a C programmer:
The 'SELECTED' option doesn't appear to do anything different than
'NORMAL'.?
The 'HILITE' option only appears to do a couple of things different than
'NORMAL' - which would be expected:
The shapes are drawn 'NORMAL' and then the color of the class for the
layer is changed to whatever the querymap->color is set to and the
processing continues as if set to 'NORMAL'.
I don't see anything that would cause the routine to exit because there
is more than 1 result shape when style is set to 'HILITE'.
However, a lot of the research is based on assumptions and it would be
helpful to know at which point it is exitting.
Do you have debugging turned on at the beginning of the script doing the
querymap draw?
Is there anything in that error log?
Thanks.
Lowell
The following message was sent by jjahn at et-inf.fho-emden.de on Thu, 25
Mar 2004 13:11:03 +0100.
> Hi,
> I get an error when I want do draw a queryMap when style=hilite or style =
> selected.
> I use perl mapscript queryByRect of one layer and the results I get
are right.
> The queryMap is drawn as long as the queryMap style is set to normal. The
> queryMap is drawn too as long as the queryMap style is set to hilite and
> numresults = 1.
> Please help me !
> This message was sent using IMP, the Internet Messaging Program.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
