[Mapserver-users] Mapserver - OGR - Oracle (revisited)
Frank Warmerdam
warmerdam at pobox.com
Wed Apr 7 17:33:16 EDT 2004
Bart van den Eijnden wrote:
> Hi Frank,
> thanks for your reaction. I have submitted an enhancement bug about this
> in the GDAL bugzilla (543).
> With regard to the DATA statement, do you have any idea why only the
> second option incorporates the BBOX in the query which is sent to Oracle?
Bart,
The problem is that OGR has a hard time (without parsing an interpreting
it) to know what table(s) a user supplied selected statement refers to.
Without that information it can't safely apply a spatial query in case
the table isn't spatially indexed (and because it doesn't know what
column to use for geometry).
> Would the only way to use a WHERE clause (or to not select all columns
> of a table) be to define a view in Oracle and use the view in the DATA
> statement?
The view might work. I think the current mechanism to test for a spatial
index is to try a small query with a spatial component. If this works, it
assumes a spatial index is available, otherwise it assumes not. So a view
might work well.
I assume you are using the query "select ORA_GEOMETRY from AdreSDO" to
avoid pulling all the unneeded extra attributes from the table? Daniel
has long suggested I should have an option in OGR to just read geometry
for features. Perhaps I should consider it more seriously.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
