[Mapserver-users] php_MapScript_41.dll - problem
Mahalakshmi Narayanan
mhln25 at yahoo.com
Thu Apr 8 01:17:27 EDT 2004
We seem to have bumped into some problem with
Php_mapscript_41.dll (or maybe something else, not
sure)
The following map file is dynamically manipulated for
drawing thematic map based on an external data
source.. The problem is if in the label object we
include FORCE TRUE then the classes are not showing up
properly. If we remove the same, some classes are
showing up .. still not all. Can somebody help me
out on this, please..
NAME DEMO
STATUS ON
SIZE 400 500
SYMBOLSET etc/symbols.sym
EXTENT 80.3527512 8.084593 76.212422 13.579674
UNITS METERS
SHAPEPATH "data/TN"
IMAGECOLOR 255 255 255
FONTSET etc/fonts.txt
WEB
IMAGEPATH "c:\inetpub\wwwroot\tmp\"
IMAGEURL "/tmp/"
END
LAYER
NAME Boundary
METADATA
"DESCRIPTION" "Boundary"
"RESULT_FIELDS" "AREA PERIMETER KARU_B_ID Bamini"
END
TYPE POLYGON
#TRANSPARENCY 100
STATUS ON
DATA dist_a1
LabelItem "Bamini"
CLASS
NAME "Tamil Nadu"
LABEL
COLOR 0 0 0
FONT Bamini
TYPE truetype
SIZE 8
POSITION CC
# PARTIALS FALSE
# FORCE TRUE
OUTLINECOLOR 255 255 255
END
STYLE
COLOR 153 102 255
OUTLINECOLOR 0 0 0
SIZE 3
END
OUTLINECOLOR 0 0 0
TEMPLATE "ttt_query.html"
END
TOLERANCE 5
END
thanks in advance..
__________________________________
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway
http://promotions.yahoo.com/design_giveaway/
