[Mapserver-users] pointObj->draw() not working!
Ken-ichi Ueda
kueda at wso.williams.edu
Sat Apr 10 17:41:53 EDT 2004
Thanks Daniel! Your script works like a charm. The problem was that I
hadn't set TRANSFORM=false for that layer, and when I did, my original
script worked too.
-Ken-ichi
On Apr 10, 2004, at 11:02 AM, Daniel Morissette wrote:
> Ken-ichi Ueda wrote:
>> Hi list. Although my previous addPoint problem remains unanswered
>> and unsolved, I have yet another problem. For some reason
>> phpMapScript's pointObj->draw() isn't working either! I've put
>> together what I think is a pretty trivial test of the function, and
>> it doesn't give any error messages, but it also doesn't draw the
>> point I want it to. I've included my version info and the test
>> script below. Please respond! Even if it looks like it should work
>> and you're clueless. I just want a little feedback.
> Something may be missing in your layer definition, but without seeing
> it we can't tell. Here is a modified version of your script that
> creates its own layer, and does display the symbol properly. You
> should compare your layer definition with what is set in this example.
> Also note that if you want to draw labels then you may have to either
> turn the labelcache off, or call $map->drawLabelCache() after drawing
> the pointObj.
> <?php
> dl('php_mapscript.so');
> // Default values and configuration
> $map_path =
> "/Library/WebServer/Documents/maplab/projects/Naturalists/";
> $map_file = "naturalists.map";
> $map = ms_newMapObj($map_path.$map_file);
> $daLayer = ms_newLayerObj($map);
> $daLayer->set("type", MS_LAYER_POINT);
> $daLayer->set("transform", MS_FALSE);
> $daLayer->set("status", MS_ON);
> $class = ms_newClassObj($daLayer);
> $style = ms_newStyleObj($class);
> $style->color->setRGB(255,0,0);
> $style->set("symbolname", "circle");
> $style->set("size", 10);
> $my_point = ms_newpointObj();
> $my_point->setXY(217,240);
> $image = $map->draw();
> $my_point->draw( $map, $daLayer, $image, 0, "Temp Point" );
> $image_url=$image->saveWebImage();
> <html>
> <head><title>point draw test</title>
> </head>
> <body>
> <img SRC="<?php echo $image_url?>" align="left">
> </body>
> </html>
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
