[Mapserver-users] Follow up to mapserver errors
Landmark Geographic Solutions
lgs at av.eastlink.ca
Thu Apr 15 09:50:11 EDT 2004
Hey guys,
Its me again, thanks for the help on the projection and the extents issues.
I don't have the mscalculatescale error or map extent error anymore. I do
have a new error, I can initiate the application no prob, it goes to my
template html document. Thing is the map window does not draw and when I
click on my map area I get this:
loadMap(): Web application error. CGI variable "map" is not set
I have been trying to look back at old email list volumes but haven't found
anything yet. Below is my test map file. Thanks for any suggestions you give
me on improving my test app.
Thanks LGS
# Start of map file
MAP
NAME xxxx
STATUS ON
SIZE 200 200
EXTENT 204545.64 4874935.38 360084.73 4993068.92
UNITS METERS
SHAPEPATH "data"
IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
PROJECTION
"proj=utm"
#"ellps=nad83"
"zone=20"
#"north"
#"no_defs"
END
WEB
# MAXSCALE 1600000
# MINSCALE 500000
TEMPLATE "test.html"
# IMAGEPATH "set in index_test.html"
# IMAGEURL "set in index_test.html"
END
# Start of layer definitions
LAYER
NAME LD
TYPE POLYGON
STATUS ON
# MAXSCALE 1500000
# MINSCALE 700000
DATA land
END
END # Map File
