[Mapserver-users] Preperation for 4.2 release, update of [shpxy...]
tag...
Paul Spencer
spencer at dmsolutions.ca
Thu Apr 15 13:04:34 EDT 2004
Steve,
is transform gone or just deprecated? It would probably be useful to
just deprecate it for one version to allow everyone to convert their
code and make it work with certain release versions ..
Paul
Steve Lime wrote:
> Hi Folks: This is just a heads up for folks using the [shpxy...] tag in
> 4.1. I've done a bit of
> clean up on the tag to make it more useful. Gone is the transform
> attribute and there is
> a new proj attribute. That attribute allows you to specify an output
> projection for a feature.
> You can set proj="image" to output the feature in image coordinates
> suitable for an
> imagemap. Otherwise proj takes a Proj.4 projection string. Note that
> the layer associated
> with a feature must contain a projection object. There still may be
> issues with "image"
> coordinates IF the output map is in a different coordinate system than
> the layer.
> Without any proj attribute coordinates (at this point) are given in the
> native projection
> of the layer.
> Any help testing would be appreciated!
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
