RES: [Mapserver-users] Query on symbols
Murilo Lacerda Yoshida
murilo.yoshida at agx.com.br
Fri Apr 16 13:20:09 EDT 2004
Yep, you understood my problem... And you also gave a great
suggestion!!
I was beginning to code the Eric suggestion, but to do that I would
have to leave some part of the map file hard coded, and I didn't want
to...
Thanks, I'll try it now, and thanks to all the people who helped me
trough this problem.
Murilo
-----Mensagem original-----
De: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] Em nome de Norbert
Thieme
Enviada em: sexta-feira, 16 de abril de 2004 04:00
Para: murilo.yoshida at agx.com.br
Cc: mapserver-users at lists.gis.umn.edu
Assunto: Re: [Mapserver-users] Query on symbols
Hello,
I hope that you found a way to solve your problem. If not I have a
suggestion that might help. Hopefully I get your problem right. Let's
see. I think you are using php/mapscript and the querybypoint function?
And you have symbols on a point layer that should represent the points?
When you do a click on the symbol you want to get the attributes from
the points?
Perhaps someone from the list can confirm this because I havn't tried it
yet.
Try this:
Loop through your layers and check the layer->type and when it is 0 then
you have a point layer. Then you can set the tolerance big enough to
match your symbols. In all other cases you can do your querybypoint on
the layer with tolerance 0 or what you want.
It could look like:
for ($i=0; $i < $map->numlayers; $i++)
$layer = $map->getLayer($i);
if ($layer->type == 0)
if (@$layer->queryByPoint($query_point, MS_MULTIPLE, 10) ==
MS_SUCCESS)
else
if (@$layer->queryByPoint($query_point, MS_MULTIPLE, 0) ==
MS_SUCCESS)
Regards,
Norbert
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
