RES: [Mapserver-users] Installing PHP MapScript
Gabriel Moricz
gabriel at autofax.com.br
Fri Apr 16 15:14:26 EDT 2004
Thanks..
Well...I did what u said me to do, but it returns a error when I try to RUN
MapLAB..
the error is:
Warning: Wrong parameter count for mkdir() in
/var/www/maplab/htdocs/common/session/session.php on line 82
/var/www/maplab/htdocs/common/session/session.php on line 189
it happened when I tried to open the maplabs/htdocs/ by my webrowser..
How must I install maplab?
Whats is wrong?
thanks..
Gabriel Moricz
-----Mensagem original-----
De: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Em nome de qoelheX
Enviada em: sexta-feira, 16 de abril de 2004 13:46
Para: mapserver-users at lists.gis.umn.edu
Assunto: Re: [Mapserver-users] Installing PHP MapScript
Gabriel Moricz wrote:
>Hello @ all..
>Well..
>I have installed MapServer, with Jpeg, Gdal, PNG, Freetype, GD, HTTPD,
PHP4,
>OGR and so on...
>Well
>I build the map server with these options and at the /mapscript/php3/
>I have all necessary files, like mapscript_i.o,php_mapscript.o,
>php_mapscript.h, well..As I said all is compiled and ok...
>But now...What Must I do???
>I dont know where to go, and what to do..
Try to copy the php_mapscript.so from folder mapscript/php3 of your
mapserv source tree to folder extensions on the php install dir.
So, enable extensions in your php.ini or load it with dl(
"php_mapscript.so" ) on top of your php script!
All right?
by qoelheX
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
