[Mapserver-users] Projection Questions
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Apr 17 16:53:08 EDT 2004
Anna,
You need to do two things.
1) in the main MAP definition of the map file you need to specify what
projection you want your map image to be displayed in with a PROJECTION
... END block.
2) in each data LAYER you need to specify what PROJECT the data is in
using a PROJECTION ... END block for that layer.
Mapserver will take care of the rest for you.
-Steve W.
Anna Blanchard wrote:
> Hi -
> I'm new at this and have a couple of possibly easy questions -
> I'm having trouble seeing my data in my mapserver because of the
> projection - With one set of data that uses a State Plane projection
> system I see everything fine - however two of my layers use a different
> projection (Lambert Conformal Conic) - how do i get these layers to
> display? I've seen the porjection function in others code however i
> don't know what the definitions of those variables -
> the variables are that I can't define are:
> PROJECTION
> "proj=utm"
> "ellps=GRS80"
> "zone=12"
> "north"
> "no_defs"
> END
> any suggestions would be great! thanks -
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
