[Mapserver-users] View problem with overlaying WMS layers
Lars Holm Loldrup LLO at CARLBRO.DK
Tue Apr 20 04:47:28 EDT 2004
Look's like bug 468 - http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=468
Regards Lars Loldrup.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Tommer
Sent: Monday, April 19, 2004 11:46 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] View problem with overlaying WMS layers
I'm using MapServer 4.02 and I have a problem with viewing of WMS connected
layers from other servers. When only one WMS layer is on, everything is OK.
But when I turn on more layers, only one is shown. Problem is not with
transparency, all layers are transparent, because I can see local layers
bellow, when only one remote layer is turned on. Sometimes, when I turn
several times on and off one layer and the other one is on, this two layers
are shown correctly. Sometimes the original layer turnes to grayscale,
however. And sometimes is shown nothing at all. Is it problem on our side in
the mapfile or in the MapServer? Or would it be problem with remote WMS
connected server? Thank you for a help. Tom Mercl
Here is part of my map file.
MAP
  NAME VODA
  STATUS ON
  SIZE 400 400
  EXTENT -680105 -1074328 -616947 -1044180 #zobrazený výøez
  UNITS METERS
  SHAPEPATH "voda"
  #IMAGECOLOR 255 255 255
  TEMPLATEPATTERN "itasca"
  IMAGETYPE GIF
  TRANSPARENT TRUE
  FONTSET "fonts/fonts.list"
  # Webové rozhraní a WMS parametry
  WEB
    HEADER templates/header.html
    TEMPLATE "set in index.html"
    FOOTER templates/footer.html
    #MINSCALE 1000
    #MAXSCALE 1550000
    IMAGEPATH "c:/mapserver/aplikace/tmp"
    IMAGEURL "c:/mapserver/aplikace/tmp"
    METADATA
      WMS_TITLE "Pardubicko - vody"
      WMS_ABSTRACT "Informaèní mapový server o ¾ivotním prostøedí
pardubického regionu"
      WMS_ACCESSCONSTRAINTS none
      # change this value to match your setup
      WMS_ONLINERESOURCE
"http://localhost.localdomain/mapserver_demos/itasca/index.html"
      WMS_SRS "EPSG:2065"
    END
  END
 LAYER # Zaèátek vrstvy
   NAME         pa-ot10
   DATA         pa-ot10
   STATUS       off
   TYPE         point
   PROJECTION
     "init=epsg:2065"
   END
    CLASS
     NAME		"Plavební komora"
     COLOR        	0 0 0
     SYMBOL   	        'symboly/ot10.gif'
    END
    METADATA
      WMS_TITLE     "pa-ot10"
      WMS_ABSTRACT  "Plavební komora"
      WMS_SRS       "EPSG:2065"
    END
 END # Konec vrstvy
   NAME         pa-ot09
   DATA         pa-ot09
   STATUS       off
   TYPE         point
   PROJECTION
     "init=epsg:2065"
   END
    CLASS
     NAME		"Pøístav"
     COLOR        	0 0 0
     SYMBOL   	        'symboly/kotva.gif'
    END
    METADATA
      WMS_TITLE     "pa-ot09"
      WMS_ABSTRACT  "Pøístav"
      WMS_SRS       "EPSG:2065"
    END
 END # Konec vrstvy
   NAME         znecisteni_vod_91_92
   STATUS       off
   TYPE         raster
   #TRANSPARENCY 50
   OFFSITE      255 255 255
   PROJECTION
     "init=epsg:2065"
   END
    CONNECTIONTYPE WMS
    CONNECTION
"http://www.utpcr.cz/ogcwms/servlet/com.esri.ogc.wms.WMSServlet?WMTVER=1.0.0
&SERVICENAME=environmental_degradation&REQUEST=getmap&SERVICE=WMS&LAYERS=8&T
RANSPARENT=false&FORMAT=PNG&SRS=EPSG:2065"
    CLASS
     NAME	  "Stupeò zneèi¹tìní vody 91/92"
     #COLOR        255 255 0
    END
    METADATA
      WMS_TITLE     "8"
      WMS_ABSTRACT  "Contamination degree of water pollution 91/92"
      WMS_SRS       "EPSG:2065"
    END
 END # Konec vrstvy
   NAME         vodni_plochy
   STATUS       off
   TYPE         raster
   #TRANSPARENCY 50
   OFFSITE      255 255 255
   PROJECTION
     "init=epsg:2065"
   END
    CONNECTIONTYPE wms
    CONNECTION
&SERVICENAME=environmental_degradation&REQUEST=getmap&SERVICE=WMS&LAYERS=15&
TRANSPARENT=false&FORMAT=png&SRS=EPSG:2065"
    CLASS
     NAME	  "Vodní plochy"
     #COLOR        255 255 0
    END
   # METADATA
   #   WMS_TITLE     "15"
   #   WMS_ABSTRACT  "Water surfaces"
   #   WMS_SRS       "EPSG:2065"
   # END
 END # Konec vrstvy
END # Konec mapy
____________________________________________________________
Jak mù¾e být perfektní SIEMENS C62 je¹tì pefektnìj¹í? Co tøeba takhle -
SIEMENS C62 za 977,- Kè. www.oskar.cz
http://ad.seznam.cz/clickthru?spotId=73597&section=/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
