[Mapserver-users] Compilation problem (mapserver 4.0.2) possible mygis error ...
Attila Csipa
plists at prometheus.org.yu
Tue Apr 20 11:16:05 EDT 2004
On Tuesday 20 April 2004 16:25, Herman De Pauw wrote:
> I tried to compile mapserver 4.0.2 with mygis support. I did as configure :
> ./configure --with-jpeg=/usr/local --with-freetype=/usr/local
> --with-zlib=/usr/lib --with-tiff=/usr/local --with-png=/usr/local
> --with-proj=/usr/local --with-gdal=/usr/local/bin/gdal-config
> --with-gd=/usr/local --without-pdf --with-eppl --with-httpd=/usr/sbin/httpd
> --with-postgis=/usr/local/pgsql/bin/pg_config --with-mygis=/usr/local/bin/m
>ysql_config
> Can somebody give me a clue how to fix these ?
It seems that the postgis and mygis modules use the same function names and
this causes a compilation error when you try to make a binary that supports
both. This is obviously a bug regarding namespace clashes, I'm afraid there
is no easy fix other than excluding one of them or waiting for the correction
to make it into CVS.
