[Mapserver-users] True Type Font - colour not showing
Eric Bridger
eric at gomoos.org
Wed Apr 21 11:24:36 EDT 2004
Well I was going to reply that I've used LABELANGLEITEM in MS4.0.1 with
no problems and with POINT layers. You may need to have a CLASSITEM
despite the fact that your EXPRESSION contains the field name.
Another major change in MS4.0 is the OUTPUTFORMAT section of your map
which determines the output image format and thus colormaps, etc. I'm no
expert so read up on this section of the Map file.
On Wed, 2004-04-21 at 09:59, steve wrote:
> This is a follow up from the mail I sent earlier. My rotation and all is
> working fine. I changed from POINT to ANNOTATION, (see map file section
> below), but no matter what colour I set, it always comes out grey, until I
> zoom very close, and then the set colours are seen.
> Thanks
> LAYER
> NAME "TuahTiga"
> DATA GPS1
> TYPE ANNOTATION
> STATUS OFF
> LABELANGLEITEM "Angle"
> CLASS
> NAME 'TuahTiga'
> TEXT "A"
> EXPRESSION ('[Name]' eq 'TuahTiga' AND [Posid] eq 1)
> LABEL
> TYPE TRUETYPE
> FORCE TRUE
> FONT vessel
> PARTIALS FALSE
> BUFFER 1
> OUTLINECOLOR 255 0 0
> COLOR 247 182 82
> ANTIALIAS TRUE
> POSITION CC
> SIZE 10
> END
> TEMPLATE "templates/gps.html"
> END#Class
> HEADER "templates/gps_header.html"
> FOOTER "templates/gps_footer.html"
> TOLERANCE 8
> DUMP TRUE # allow GML export
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
