[Mapserver-users] proj.4 stuff
Bob Basques
bob.basques at ci.stpaul.mn.us
Thu Apr 22 18:14:14 EDT 2004
Frank Warmerdam wrote:
> Bob Basques wrote:
>> Ok, I can't get it to work:
>> HELP!!
> This corresponds to the PROJ.4 definition:
> +proj=lcc +lat_1=44.88333333333333 +lat_2=45.13333333333333
> +lat_0=44.79111111111111 +lon_0=-93.38333333333334 +x_0=152400.3048
> +y_0=30480.06096 +a=6378418.941 +b=6357033.31
> +to_meter=0.3048006096012192 +no_defs
> I got this by putting your definition in a text file, trimming some of
> the
> HTML junk out and then doing the following. The testepsg program in
> gdal/ogr
> (needs to be forced to build ... not a default utility) converts
> between different
> coordinate system formats. The ESRI:: prefix tells the program the.
> prj file has
> ESRI WKT instead of OGR WKT.
Ok, that's cool, so that's in the GDAL stuff, interesting. Learn
something everyday. Although I didn't see any reference to it anywhere
in my searching.
So I took the above and made this Map File, is the correct way to
implement (it didn't work, I get a blank page still):
MAP
NAME 'test'
SIZE 800 650
STATUS ON
EXTENT 332000 -18000 678000 328000
UNITS FEET
PROJECTION
"init=epsg:26915"
END
LAYER
NAME 'tlg01'
DATA './data/tlg01/tlg_roads_l'
STATUS DEFAULT
TYPE LINE
PROJECTION
"proj=lcc"
"lat_1=44.88333333333333"
"lat_2=45.13333333333333"
"lat_0=44.79111111111111"
"lon_0=-93.38333333333334"
"x_0=152400.3048"
"y_0=30480.06096"
"a=6378418.941"
"b=6357033.31"
"to_meter=0.3048006096012192"
"no_defs"
END
END
END ## end Map
Thanbks for the help on this
bobb
