[Mapserver-users] Image not visible
Attri, Abhishek
aattri at cba.ua.edu
Fri Apr 23 16:56:03 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C42975.63E94206
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hi All,=20
=20
I am trying to use mapscript to display a simple image. When I add the
layers and classes in the mapfile, I get the image. But, when I try to
create the layers and classes through the mapscript, I get the image
which is not visible. Can somebody help me find out what I am doing
wrong?
=20
Here is the code for mapfile and mapscript file:-
=20
NAME FIRSTMAP
SIZE 500 500
STATUS ON
SYMBOLSET ../symbols/symbols35.sym
EXTENT -88.50 30.23 -84.88 35.02
UNITS MILES
SHAPEPATH "../data"
=20
WEB
IMAGEPATH "/home/tech/abhi/WWW/tmp/"
IMAGEURL "/tmp/"
END
=20
END
=20
=20
=20
=20
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=20
<?php
=20
dl('php_mapscript.so');
=20
$map_path=3D"/home/tech/abhi/WWW/ms/map_files/";
$map_file=3D"./Newcounty.map";
$map =3D ms_newMapObj($map_path.$map_file);
=20
=20
=20
// create layer
$layer =3D ms_newLayerObj($map);
$layer->{name} =3D "Counties";
$layer->{type} =3D MS_POLYGON;
$layer->{status} =3D MS_ON;
$layer->{data} =3D "./counties";
=20
=20
// create class
$class =3D ms_newClassObj($layer);
$class->{status}=3D MS_ON;
$class->{name}=3D "Myclass";
$style =3D ms_newStyleObj($class);
$style->{color}->{red}=3D 110;
$style->{color}->{blue}=3D 50;
$style->{color}->{green}=3D 100;
=20
$style->{outlinecolor}->{red}=3D 200;
$style->{outlinecolor}->{blue}=3D 200;
$style->{outlinecolor}->{green}=3D 200;
=20
$style->{symbol} =3D0;
=20
//Draw Image
$image=3D$map->draw();
$image_url=3D$image->saveWebImage();
=20
<HTML>
<HEAD>
<TITLE>Map 1</TITLE>
</HEAD>
<BODY>
<center>
<TABLE>
<TR><td>
<INPUT TYPE=3DIMaGe name=3Dmapa src=3D<?php echo $image_url?>>
</td></TR>
</TABLE>
<center>
</BODY>
</HMTL>
=20
With thanks in advance,
=20
Abhishek
=20
Content-Type: text/html;
charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi All, <o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I am trying to use mapscript to display a simple =
image. When
I add the layers and classes in the mapfile, I get the image. But, when =
I try
to create the layers and classes through the mapscript, I get the image =
which
is not visible. Can somebody help me find out what I am doing =
wrong?<o:p></o:p></span></font></p>
font-family:Arial'>Here is the code for mapfile and mapscript =
file:-<o:p></o:p></span></font></p>
font-family:Arial'>NAME FIRSTMAP<o:p></o:p></span></font></p>
font-family:Arial'>SIZE 500 500<o:p></o:p></span></font></p>
font-family:Arial'>STATUS ON<o:p></o:p></span></font></p>
font-family:Arial'>SYMBOLSET =
../symbols/symbols35.sym<o:p></o:p></span></font></p>
font-family:Arial'>EXTENT -88.50 30.23 -84.88 =
35.02<o:p></o:p></span></font></p>
font-family:Arial'>UNITS MILES<o:p></o:p></span></font></p>
font-family:Arial'>SHAPEPATH =
"../data"<o:p></o:p></span></font></p>
font-family:Arial'>WEB<o:p></o:p></span></font></p>
font-family:Arial'>IMAGEPATH =
"/home/tech/abhi/WWW/tmp/"<o:p></o:p></span></font></p>
font-family:Arial'>IMAGEURL =
"/tmp/"<o:p></o:p></span></font></p>
font-family:Arial'>END<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D<o:p></o:p></span></font></p=
font-family:Arial'><?php<o:p></o:p></span></font></p>
font-family:Arial'>dl('php_mapscript.so');<o:p></o:p></span></font></p>
font-family:Arial'> =
$map_path=3D"/home/tech/abhi/WWW/ms/map_files/";<o:p></o:p></sp=
an></font></p>
$map_file=3D"./Newcounty.map";<o:p></o:p></span></font></p>
font-family:Arial'> $map =3D =
ms_newMapObj($map_path.$map_file);<o:p></o:p></span></font></p>
font-family:Arial'> // create =
layer<o:p></o:p></span></font></p>
font-family:Arial'> $layer =3D =
ms_newLayerObj($map);<o:p></o:p></span></font></p>
font-family:Arial'> $layer->{name} =3D =
"Counties";<o:p></o:p></span></font></p>
font-family:Arial'> $layer->{type} =3D =
MS_POLYGON;<o:p></o:p></span></font></p>
font-family:Arial'> $layer->{status} =3D =
MS_ON;<o:p></o:p></span></font></p>
font-family:Arial'> $layer->{data} =3D =
"./counties";<o:p></o:p></span></font></p>
class<o:p></o:p></span></font></p>
font-family:Arial'> $class =3D =
ms_newClassObj($layer);<o:p></o:p></span></font></p>
$class->{status}=3D MS_ON;<o:p></o:p></span></font></p>
$class->{name}=3D "Myclass";<o:p></o:p></span></font></p>
$style =3D =
ms_newStyleObj($class);<o:p></o:p></span></font></p>
$style->{color}->{red}=3D =
110;<o:p></o:p></span></font></p>
$style->{color}->{blue}=3D =
50;<o:p></o:p></span></font></p>
$style->{color}->{green}=3D =
100;<o:p></o:p></span></font></p>
$style->{outlinecolor}->{red}=3D =
200;<o:p></o:p></span></font></p>
$style->{outlinecolor}->{blue}=3D =
$style->{outlinecolor}->{green}=3D =
$style->{symbol} =3D0;<o:p></o:p></span></font></p>
font-family:Arial'> //Draw =
Image<o:p></o:p></span></font></p>
$image=3D$map->draw();<o:p></o:p></span></font></p>
$image_url=3D$image->saveWebImage();<o:p></o:p></span></font></p>
font-family:Arial'>?><o:p></o:p></span></font></p>
font-family:Arial'><HTML><o:p></o:p></span></font></p>
font-family:Arial'><HEAD><o:p></o:p></span></font></p>
font-family:Arial'><TITLE>Map =
1</TITLE><o:p></o:p></span></font></p>
font-family:Arial'></HEAD><o:p></o:p></span></font></p>
font-family:Arial'><BODY><o:p></o:p></span></font></p>
font-family:Arial'><center><o:p></o:p></span></font></p>
font-family:Arial'><TABLE><o:p></o:p></span></font></p>
font-family:Arial'><TR><td><o:p></o:p></span></font></p>
font-family:Arial'><INPUT TYPE=3DIMaGe name=3Dmapa src=3D<?php =
echo
$image_url?>><o:p></o:p></span></font></p>
font-family:Arial'></td></TR><o:p></o:p></span></font></p>
font-family:Arial'></TABLE><o:p></o:p></span></font></p>
font-family:Arial'></BODY><o:p></o:p></span></font></p>
font-family:Arial'></HMTL><o:p></o:p></span></font></p>
font-family:Arial'>With thanks in advance,<o:p></o:p></span></font></p>
font-family:Arial'>Abhishek<o:p></o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C42975.63E94206--
