[Mapserver-users] OGR + DGN STYLEITEM "AUTO" config
Tyler Mitchell
TMitchell at lignum.com
Mon Apr 26 14:40:30 EDT 2004
FYI - also note that when using AUTO, some elements may not be visible
depending on the background colour of your map. That's not your problem
here, but it stumped me for a while since text in Microstation that was
black (in the Microstation program) came out as white in MapServer. We
almost need a parameter to move black<->white as desired.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 04/26/2004 10:54:43 AM:
> Frank,
> Following your suggestion I left out the CLASS info and added the
STYLEITEM
> "AUTO". This only results in a blank map!
> However, adding a CLASS definition using a 'dummy' color (255 255 255 or
> whatever color you like) gives a good result. Using an empty class
(CLASS
> immediately followed by END) does not do the trick. So here is an
abstract
> of the mapfile used:
> LAYER
> STATUS ON
> GROUP DGN
> CONNECTIONTYPE OGR
> CONNECTION "C:\inetpub\wwwroot\vinya\data\xarxa_i07.dgn"
> NAME "Sorea"
> TYPE line
> TOLERANCE 10
> STYLEITEM "AUTO"
> METADATA
> WMS_TITLE "Sorea DGN"
> WMS_SRS "EPSG:23031"
> WMS_EXTENT "420426,55 4591480,93 421308,65 4591676,52"
> END
> PROJECTION
> "init=epsg:23031"
> END
> CLASS
> color 255 255 255
> END
> END
> Best regards,
> Menno
> -----Mensaje original-----
> De: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Enviado el: lunes, 26 de abril de 2004 18:27
> Para: Schepel, Menno
> CC: UMN MapServer
> Asunto: Re: [Mapserver-users] OGR + DGN STYLEITEM "AUTO" config
> Schepel, Menno wrote:
> > LAYER
> > STATUS OFF
> > GROUP DGN
> > CONNECTIONTYPE OGR
> > CONNECTION "C:\inetpub\wwwroot\vinya\data\granollersv7.dgn"
> > NAME "Granollers"
> > TYPE Line
> > TOLERANCE 10
> > METADATA
> > WMS_TITLE "Granollers DGN"
> > WMS_GROUP_TITLE "OGR-DGN Test Files"
> > END
> > PROJECTION
> > "init=epsg:23031"
> > END
> > CLASS
> > COLOR 255 0 0
> > END
> > DUMP TRUE
> > TEMPLATE "templates/Granollers.html"
> > HEADER "templates/Granollers_header.html"
> > FOOTER "templates/Granollers_footer.html"
> > END
> > I have found some examples of using MapInfo files in the forum and on
the
> > sites of MapServer and DM solutions, but until now I did not see an
> example
> > using DGN. The manual is mentioning that it should be possible,
however.
> > What do I have to put in the symbol file in order that it will
recognize
> the
> > different styles used within the DGN?
> > Is there someone who has some experience with this that they could
share?
> > Thanks,
> Menno,
> In general you should just be able to add STYLEITEM "AUTO" to your layer
> definition, and perhaps remove your CLASS definition. This should cause
> MapServer to use the OGR style information. There should not be any
> changes to symbol files required. I don't think any of the DGN
autostyled
> stuff uses symbols.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
