[Mapserver-users] complex postgis queries in mapserver
andreas.mueller at bfua.de
Tue Apr 27 14:29:52 EDT 2004
although there has been a lot of mails about this problem I still don't figure it out.
When I enter a simple query:
DATA "the_geom FROM ruhr"
I get a nice map.
But if I do a join on two tables in the same way as the documentation (and about 5
million mails from this list) says, I get the well known error message:
msDrawMap(): Image handling error. Failed to draw layer named 'ruhr'.
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
hp1::text,asbinary(force_collection(force_2d(x3x3)),'NDR'),oid::text from
x3x3 WHERE x3x3 && setSRID('BOX3D(2510000
5608433.33333333,2680000 5778566.66666667)'::BOX3D, -1 )'
and so on
The subquery is fine for PostgreSQL. We have an alias for the result set. We use "oid"
as UNIQUE and "SRID" as well.
The layer definition is as follows:
LAYER
NAME ruhr
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "user=andy dbname=mygisdb host=localhost password=harry"
DATA "the_geom FROM (SELECT ruhr.oid AS oid, ruhr.the_geom AS the_geom,
ruhr_small.hp1 AS hp1 FROM ruhr LEFT JOIN ruhr_small ON ruhr.gewkz =
ruhr_small.gewkz AND ruhr.stat = ruhr_small.abschnitt ) AS test USING UNIQUE oid
USING SRID=-1"
STATUS DEFAULT
CLASSITEM hp1
CLASS
EXPRESSION "1"
My Mapserver version is running on my Win 2k desktop:
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I'm running PostGIS 0.81 and PostgreSQL 7.4.1.3 within Cygwin.
Where is the mistake?
Thanks
Andreas
Dr. Andreas Müller
Medien und Umwelt
Breite Straße 21 Rüttenscheider Straße 61
53111 Bonn 45130 Essen
Tel.: 02 28.9 73 83 90 Tel.: 02 01.79 49 41
Fax: 02 28.9 73 83 91 Fax: 02 01.79 49 42
info at m-u-u.de www.m-u-u.de
