[Mapserver-users] QueryByAttribute
Norbert Thieme norbert.thieme at ilmenau.baw.de
Wed Apr 28 05:19:41 EDT 2004
Don't you get an error message if you launch queryByAttributes. If you
don't use the @ before there should be a message if an error occurs. If
not there must be something wrong in the script.
I think you didn't copy/paste the code? Sorry for the question because I
think php would in the other case report an error on the line with:
    if ( $oQueryStatus = MS_FAILURE )
because "==" instead of "=".
I don't know if this helps you but here is a snippet from the code I
use. Even if I use queryByPoint you can try to use your
queryByAttributes the same way:
if (@$layer->queryByPoint($q_point, $q_mode, 0) == MS_SUCCESS)
   $res_count = $layer->getnumresults();
   for ($i=0; $i < $res_count; $i++)
     $result = $layer->getResult($i);
I don't know if this solves the problem but I hope it will help you.
Regards,
Norbert
