[Mapserver-users] My first label configuration (with angles)
Ryan, Adam ARyan at co.linn.or.us
Wed Apr 28 18:10:41 EDT 2004
Bob,
1. Try the POSITION parameter in the LABEL object in your map file.
2. One way I've tried is to duplicate the name attribute and then delete the
values from all those roads that you don't want labeled (all the little
curves).  It's less dynamic but can have nice results.
Adam
-----Original Message-----
From: bob.basques at ci.stpaul.mn.us [mailto:bob.basques at ci.stpaul.mn.us]
Sent: Wednesday, April 28, 2004 1:39 PM
To: Mapserver List
Subject: [Mapserver-users] My first label configuration (with angles)
All,
Is the only way to rotate a labelitem by having a column with the
rotation in the DBF?
Can't a labelitem be aligned somehow with the linework (street
centerlines) that it's bound to.
Also, what's the procedure for filtering only one coccurance of a label,
each segment has a street identifier, how do I only label one of the
same street segments, vs all of the same street named segment?
Thanks'
bobb
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
