[Mapserver-users] WMS test mapfile and Test server would be appreciated
Arnulf Christl
arnulf.christl at ccgis.de
Thu Apr 29 09:42:09 EDT 2004
This is a multi-part message in MIME format.
--------------070109020808000301050608
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
get the WMS GetCapabilities URL here:
http://wms.ccgis.de/umn/bin/mapserv.exe?map=d:/umn/germany.map&request=capabilities&wmtver=1.0.0
Corresponding MAP file which cascades this service is attached (modify
server URLs and paths to match your installation). What I didn't know
was that the UMN needs the IMAPGEPATH und URL although it is requested
as a WMS because it saves the image of the cascaded WMS in the temporary
sessions dir.
We put the project on our backup server, so you can have a look at the
results in a client.
http://wms1.ccgis.de/
Select the project <test_cascading_wms>
We met some "interesting phenomena" while toying your problem on four
different UMN MapServer installations - problems with the PNG lib which
was used instead of the OGR. MS 4.01 on Windows 2000 didn't work, MS 4.2
on FreeBSD does.
Regards, Arnulf.
Nicolas Boretos wrote:
> Hi Again,
> I gues the topic says it all
> need a sample mapfile to test WMS client capability of my ms
> installation...
> regards,
> nicolas
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
CCGIS Christl & Stamm GbR
http://www.ccgis.de
http://www.mapbender.org
Service: +49 (0)228 90826 0
Direct: +49 (0)228 90826 23
Fax: +49 (0)228 90826 11
Siemensstraße 8
53121 Bonn
GERMANY
name="test_cascading_wms.map"
Content-Disposition: inline;
filename="test_cascading_wms.map"
MAP
NAME "test_cascading_WMS"
STATUS ON
EXTENT 4426500 5466000 4448000 5490200
PROJECTION
"init=epsg:31494"
END
SIZE 650 420
IMAGECOLOR 255 255 255
TRANSPARENT ON
UNITS meters #Units mapcoordinates; für scale/scalebar Berechnungen
RESOLUTION 72 #Pixel/inch für Output (scalecomputation; def 72), vorher 300
INTERLACE OFF
IMAGETYPE PNG #output imagetype
WEB
MINSCALE 0
MAXSCALE 2000000
LOG "test_cascaded.log"
IMAGEPATH "/data/umn/umn-www/sessions/"
IMAGEURL "http://wms1.ccgis.de/umn/sessions/"
METADATA
"WMS_TITLE" "test_cascading_wms"
"WMS_ABSTRACT" "Test cascading WMS"
"WMS_ACCESSCONSTRAINTS" "none"
"WMS_SRS" "epsg:31494"
"WMS_ONLINERESOURCE" "http://192.168.2.71/cgi-bin/mapserv?map=/data/umn/test_cascading_wms.map"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
END
END
LAYER
NAME "cascaded_WMS"
TYPE RASTER
STATUS ON
CONNECTION "http://wms.ccgis.de/umn/bin/mapserv.exe?map=d:/umn/germany.map&wmtver=1.0.0"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "epsg:31494"
"wms_title" "cascaded WMS"
END
PROJECTION
"init=epsg:31494"
END
END
END
--------------070109020808000301050608--
