[Mapserver-users] Nasty bug in labelcache?
Daniel Morissette
dmorissette at dmsolutions.ca
Thu Apr 29 17:48:13 EDT 2004
If you can prepare a test case to reproduce this (i.e. small dataset and
mapfile) with MapServer 4.2 then please submit it as a bug in bugzilla
and we'll have a look. Otherwise without a way to reproduce the problem
there is not much we can do to help unfortunately.
Daniel
Paco Regodon wrote:
> I added a new layer to my map. It is a points layer with wind data. I needed
> to draw arrows showing wind direction, this way:
> LAYER
> NAME wind
> DATA wind
> TYPE POINT
> PROJECTION "proj=utm" "zone=30" END
> STATUS DEFAULT
> LABELANGLEITEM "DIR"
> CLASS
> TEXT '>'
> LABEL
> FONT "arial"
> TYPE TRUETYPE
> ANTIALIAS TRUE
> COLOR 0 0 0
> SIZE 40
> ANGLE AUTO
> END
> END
> END
> About 50% of the times, cgi returns an invalid image, or a text/html white
> page. I tried to use different output formats (PNG, PNG24, JPEG), upgraded
> gd2 and freetype without success.
> When i added:
> LABELCACHE OFF
> Everything worked fine.
> Is it a bug? Was i doing something wrong?
> I am using this rpm's:
> mapserver-4.0-1mdk
> freetype-1.3.1-18mdk
> freetype2-2.1.3-12plf
> libgd2-2.0.22-1mdk
> libgdal0-1.1.9-2mdk
