[Mapserver-users] Tolerance Problem
Sam Choudry
samuzzal at linux.net
Fri Apr 30 05:30:46 EDT 2004
Thank you Thieme for your advice. But my problem is that
querybypoint() itself is not working because of what I think
'Tolerance'. Can anybody put some light in this regard. I am
again attaching my previous mail.
I am providing herewith the code I am using for querying
a point layer.
$query_on = TRUE;
$map_height = $map->height;
$map_width = $map->width;
$minX = $map->extent->minx;
$minY = $map->extent->miny;
$maxX = $map->extent->maxx;
$maxY = $map->extent->maxy;
$geo_x = Pix2Geo($x_pos,0,$map_width,$minX,$maxX,0);
$geo_y = Pix2Geo($y_pos,0,$map_height,$minY,$maxY,1);
$GeoPosition = ms_newPointObj();
$GeoPosition->setXY($geo_x, $geo_y);
echo "$geo_x,<br>";
echo "$geo_y<br>";
$Layer = $map->getlayerbyname("pt-barama");
//$Layer->toleranceunits = MS_PIXELS;
$result = $Layer->queryByPoint($GeoPosition,MS_SINGLE,-1);
echo "$result";
The portion of the Map file used is :
LAYER
NAME "pt-barama"
DATA "pt-barama"
TOLERANCEUNITS pixels
TOLERANCE 10
STATUS ON
TYPE POINT
CLASS
COLOR 100 100 100
OUTLINECOLOR 0 0 0
SYMBOL 'circle'
END # end of class object
END
And the Error Message is :
Warning: [MapServer Error]: msQueryByPoint(): No matching record(s)
found. in c:\inetpub\wwwroot\php\nalbari\barama.php on line 81
I tested with different tolerence units and also tolerance values,
but the problem remains. Can anybody show me the problem in coding?
regards,
Samuzzal
_____________________________________________________________
Linux.Net -->Open Source to everyone
Powered by Linare Corporation
http://www.linare.com/
