[Mapserver-users] problem with PostGIS layers with a bit() column
Perry Casson perry.casson at waypointinfo.com
Fri Apr 30 10:13:52 EDT 2004
I'm quite new to all this MapServer stuff but there appears to be a bug
when calling layer->getShape() on a PostGIS layer that contains columns
that are of of type bit().  I see the code in mappostgis.c that builds
this query but I'm not up to speed enough to know if the problem should
be fixed there or farther up stream.   I'm running 4.0.2 (Linux)
Here's the error:
Fatal error: [MapServer Error]: msPOSTGISLayerGetShape(): Error
executing POSTGIS SQL statement (in FETCH ALL): DECLARE mycursor2 BINARY
CURSOR FOR SELECT
esn::text,gmuid::text,messageid::text,timestamp::text,recievedat::text,devicetype::text,identifier::text,isgps::text,longitude::text,latitude::text,gpsvalid::text,gpstime::text,v1::text,v2::text,v3::text,max1::text,max2::text,max3::text,actuator_previous::text,actuator_current::text,userdata::text,battery::text,asbinary(force_collection(force_2d(geo)),'NDR')
from wp_point WHERE OID = 27497 -ERROR: Cannot cast type bit to text
and here how the table being queried is created:
CREATE TABLE wp_point(ESN varchar(12), gmUID varchar(40), messageID
varchar(40), TimeStamp timestamp, RecieveDat timestamp, DeviceType
varchar(32), Identifier varchar(32), IsGPS varchar(2), Longitude float8,
Latitude float8, GPSValid varchar(2), GPSTime timestamp, V1 int2, V2
int2, V3 int2, Max1 int2, Max2 int2, Max3 int2, Actuator_Previous bit(8)
, Actuator_Current bit(8) ,UserData varchar(64), Battery varchar(8));
SELECT AddGeometryColumn('sentinel', 'wp_point', 'geo', 4326,
'GEOMETRY', 2);
Perry Casson
