[UMN_MAPSERVER-USERS] Labels Problem
Steve Lehr
lehrs at ERAU.EDU
Wed Aug 11 17:29:00 EDT 2004
Skweda:
Its hard to tell from your map file you've given. Is the data you have an
annotation or is it a line type. If its a line type it should work, but if
its an annotation, the labels go where they have placed them. I always try
to get road center lines with a road name attribute. Perhaps if you have a
line_id with your road names and a matching attribute in the annotation you
can alter your DBF and merge in the road name attribute.
Steven Lehr
Assistant Professor
College of Engineering
Embry-Riddle Aeronautical University (LB159)
600 S. Clyde Morris Blvd.
Daytona Beach, FL 32114-3900
386-226-7740
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Skweda O'Bomsawin
Sent: Wednesday, August 11, 2004 5:24 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] RE : [UMN_MAPSERVER-USERS] Labels Problem
Thanks Steve, but that doesn't resolve my problem... I keep searching!
Skweda
-----Message d'origine-----
De : Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Envoyé : 11 août 2004 17:07
À : Skweda O'Bomsawin
Cc : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] Labels Problem
Try removing the "POSITION UC"
-Steve
Skweda O'Bomsawin wrote:
> Hi list!
> I have a weird label problem with Mapserver. I try to display street
names
> with an angle set to auto. My map file looks like this:
> CLASS
> Name 'road_labels'
> LABEL
> TYPE TRUETYPE
> FONT "arial"
> SIZE 7
> MINSIZE 4
> MAXSIZE 256
> POSITION UC
> ANGLE AUTO
> BUFFER 2
> MINDISTANCE 150
> MINFEATURESIZE 20
> COLOR 100 50 0
> SHADOWCOLOR 0 0 0
> SHADOWSIZE 0 0
> PARTIALS FALSE
> END
> END # Class
> As you can see on the picture I have sent, I am unable to get the labels
> centered on the street lines. Some names are as far as 400m from the
center
> of the street and the translation seems to be always parallel to the
street
> line. I'm using Mapserver 4.0 with Postgis 0.7 on a Whitebox Linux with
gd
> 1.8.4-12 and freetype 2.1.4-4.
> Thanks!
> Skweda O'Bomsawin
> sobomsawin at kassini.com
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.735 / Virus Database: 489 - Release Date: 2004-08-06
Incoming mail is certified Virus Free.
