problematic map file
Pagurek, Debbie
PAGUREKD at AGR.GC.CA
Tue Aug 17 09:02:10 EDT 2004
Check your IMAGEPATH and IMAGEURL. Something doesn't look quite right to
me.
In my mapfile it looks like this:
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
Your IMAGEURL should be the URL used to point to where your images are.
e.g. http://localhost/ms_tmp/blahblah.png
hopefully this helps.
Debbie
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Oliver Ishmael
Sent: Monday, August 16, 2004 6:31 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] problematic map file
Hi All,
I have been trying to display a map of the world using the attached .MAP
file (also displayed below), however, this has met with limited success.
All that i have managed to display is the .HTML template, unfortunately
no
image is displayed and no error messages are displayed.
It might be a lot to ask but if you can see anything i've missed i would
really appreciate any help you can provide.
Cheers
Oliver Ishmael
MAP
NAME world_tm
IMAGETYPE PNG
EXTENT 148.3 198.0 198.0 120.7
SIZE 600 400
SHAPEPATH "mapserver/data/"
# Index of
colours...http://webmonkey.wired.com/webmonkey/reference/color_codes/
IMAGECOLOR 95 158 180
WEB
TEMPLATE 'world_tm.html'
IMAGEPATH '../mapserver/data/tmp/'
IMAGEURL '../mapserver/data/tmp/'
END
PROJECTION
# this code can be found in the "epsg.file" (when opened in txt ed. it
lists every projection
# and their respective epsg codes)
"init=epsg:2156"
# for some reason this projection is usually dif from the layer
projection...why?!
END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 200 2
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
# Start of LAYER DEFINITIONS
LAYER # African continent polygon layer begins here
NAME Africa
DATA Africa
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Egypt using UTM (just picked a country in
Africa at random!)
"init=epsg:4198"
END
CLASS
COLOR 255 255 0
OUTLINECOLOR 255 255 0
END
END # African continent polygon layer ends here
LAYER # Asian continent polygon layer begins here
NAME Asia
DATA Asia
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for India (just picked a country in Asia at
random!)
"init=epsg:4238"
END
CLASS
COLOR 178 34 34
END
END # Asian continent polygon layer ends here
LAYER # Australasian continent polygon layer begins here
NAME Australasia
DATA Australasia
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Australia (just picked a country in
Australasia
at random!)
"init=epsg:4002"
END
CLASS
COLOR 178 34 34
END
END # Australian continent polygon layer ends here
LAYER # European continent polygon layer begins here
NAME Europe
DATA Europe
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Ireland using UTM (just picked a country in
Europe at random!)
"init=epsg:2156"
END
CLASS
COLOR 178 34 34
END
END # European continent polygon layer ends here
LAYER # North American continent polygon layer begins here
NAME NorthA
DATA NorthA
STATUS DEFAULT
TYPE POLYGON
PROJECTION
# this is the exact code for Illinois (just picked a state in North
America
at random!)
"init=epsg:26770"
END
CLASS
COLOR 178 34 34
END
END # North American continent polygon layer ends here
LAYER # South American continent polygon layer begins here
NAME SouthA
DATA SouthA
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Brazil (just picked a country in South
America
at random!)
"init=epsg:28992"
END
CLASS
COLOR 178 34 34
END
END # South American continent polygon layer ends here
# End of LAYER DEFINITIONS ---------------------------------------------
END # end of map file/object
_________________________________________________________________
Use MSN Messenger to send music and pics to your friends
http://www.msn.co.uk/messenger
