I would appreciate any help I can get on getting this map to
work...
David Fawcett
David.Fawcett at STATE.MN.US
Fri Aug 20 09:34:59 EDT 2004
Reuven,
A couple of things to try:
1. Set the STATUS of each layer to 'default'. When a layer status is
set to 'on', you need to specify the layer name in the URL to display or
query it. Default will make it show up.
2. If that doesn't work, comment out your projection info. If all of
your layers are in the same projection, you don't need to include
projection info in your Map file.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Reuven Levitt <reuven at LEVITT.NET> 8/20/2004 7:50:32 AM >>>
Hi Everyone,
I am new to the list.
I just started working on a project, and as the first
order of business I need to get mapserver up and
running (which I have done). However I tried to get
my own thing working (Spend a lot of hours reading),
and I am still having some trouble.
This is actually one of the demos, so it should work,
but by image is coming back blank white.
Here is the map file (reuven.map):
MAP
NAME REUVEN
STATUS ON
IMAGETYPE PNG
SIZE 800 500
SHAPEPATH
"E:/Dev/Tools/mapserver/workshop/reuven/data/"
EXTENT -6086744.000 -2784127 4278894 4485901
UNITS METERS
PROJECTION "proj=laea" "lat_0=45" "lon_0=-100"
"ellps=GRS80" "datum=NAD83" END
WEB
IMAGEPATH "E:/Dev/Source/web/workshop/tmp/"
IMAGEURL "/workshop/tmp/"
TEMPLATE "reuven.html"
END
LAYER
NAME "lights"
TYPE RASTER
STATUS ON
DATA
"E:/Dev/Tools/mapserver/workshop/reuven/data/nitelti020l.tif"
END
LAYER
NAME "boundaries"
TYPE POLYGON
STATUS ON
DATA "statesp020"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "US states"
OUTLINECOLOR 50 50 50
SYMBOL 0
END
END
END
All of the files are under the following directory:
(including: nitelti020l.tif and
statesp020.shp/shx/dbf)
This is the template contents (reuven.html in same
directory as map file):
<input type="image" name="img" src="[img]"
width="[mapwidth]" height="[mapheight]" border="0"
alt="this is the map">
I am calling the server with the following URL:
http://localhost/cgi-bin/mapserv.exe?&map=E:/Dev/Source/web/workshop/reuven.map
Version information:
MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLI
ENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
I am sure the problem is something simple, but I am
just not seeing it.
Thanks in advance for any help,
Sincerely,
Reuven
