Mapserver on WinXP - known problems?
Reuven Levitt
reuven at LEVITT.NET
Mon Aug 23 19:00:21 EDT 2004
Thanks for the tip.
The text is still not showing up, but the server is
not crashing any more. Do you have a sample flash map
file that uses text labels?
Thanks,
Reuven.
--- Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> wrote:
> The flash output does not support True type fonts.
> It uses fonts called
> "FDB". The reason is that the underlying library
> (ming) only supports
> those fonts. You can download some FDB fonts at the
> ming web site
> http://ming.sourceforge.net/.
> Reuven Levitt wrote:
> > Hey Robert,
> > I am quite new, but I am running Mapserver on XP
> so
> > far with no problems at all. TrueType font works
> > fine, however I am running into a problem using
> the
> > Flash (SWF) output with Multiple layers on text
> > output. I dont know if this is an XP specific
> problem
> > or one specific to my setup.
> > Reuven.
> > --- Robert <robert-fritz at WEB.DE> wrote:
> >>hello,
> >>does anybody have trouble to run mapserver on
> >>WindowsXP? i know, that there
> >>is a problem using truetype fonts
> >>for labeling and XP, but are there other known
> >>restrictions / problems?
> >>Are there differences between XP-versions (XPPro,
> XP
> >>TabletEdition, ...?)
> >>Thank you for your help,
> >>robert
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
