JPEG 2000 format instead of TIFF for a RASTER layer
Brant Anderson
brant at MUDLABS.COM
Thu Aug 26 02:40:05 EDT 2004
Here are some more details:
Mapfile: ( Full mapfile can be found here:
http://mudlabs.homelinux.org:8181/mapserver_dev/Douglas.map )
---->snip<----
LAYER
NAME 'index'
TYPE TILEINDEX
DATA 'dougIndex_jp2.shp' # JPEG2000 Images in same folder as
Shapefiles (TESTING)
#DATA 'dougIndex_ortho.shp' # TIFF Images in 'ortho' sub-folder
(WORKING)
#DATA 'dougIndex.shp' # TIFF Images in same folder as Shapefiles
(WORKING)
END
LAYER
NAME 'test_raster'
STATUS OFF
TYPE RASTER
TILEINDEX 'index'
TILEITEM 'PATH'
END
---->snip<----
The 'tile index' layer was created via an ArcGIS extension written by
Mike Juvrud of Mud Labs. What it does is takes the Orthophoto/raster
image from a MrSID format, and chops it up into tiles, outputting the
tiles as TIFF formatted images (max 50MB per image). At the same time,
it generates the 'tile index' layer, filling in the corresponding
filename in an attribute named 'PATH'.
After verifying this method worked using TIFF files, the 'PATH'
attribute was changed from a .tif extension to a .jp2 extension. So if I
had an image named '104.tif' the new name would be '104.jp2'
I used the 'jasper' utility to convert the TIFF image to a JPEG2000
using the command: 'jasper -f 104.tif -t tif -F 104.jp2 -T jp2'
Here is the output from ogrinfo of a TIFF version, and another of the
JPEG2000 version.
==TIFF: (command used: 'ogrinfo dougIndex.shp dougIndex')
INFO: Open of `dougIndex.shp'
using driver `ESRI Shapefile' successful.
Layer name: dougIndex
Geometry: Polygon
Feature Count: 7
Extent: (285931.949063, 5109160.000042) - (289100.000009, 5109580.000043)
Layer SRS WKT:
(unknown)
PATH: String (15.0)
STATUS: Integer (4.0)
IndexID: Integer (9.0)
OGRFeature(dougIndex):0
PATH (String) = 104.tif
STATUS (Integer) = 1
IndexID (Integer) = 104
POLYGON ((286040.000 5109160.000,285931.949 5109160.000,285945.481
5109580.000,286040.000 5109580.000,286040.000 5109160.000))
OGRFeature(dougIndex):1
PATH (String) = 105.tif
IndexID (Integer) = 105
POLYGON ((286550.000 5109160.000,286040.000 5109160.000,286040.000
5109580.000,286550.000 5109580.000,286550.000 5109160.000))
OGRFeature(dougIndex):2
PATH (String) = 106.tif
IndexID (Integer) = 106
POLYGON ((287060.000 5109160.000,286550.000 5109160.000,286550.000
5109580.000,287060.000 5109580.000,287060.000 5109160.000))
OGRFeature(dougIndex):3
PATH (String) = 107.tif
IndexID (Integer) = 107
POLYGON ((287570.000 5109160.000,287060.000 5109160.000,287060.000
5109580.000,287570.000 5109580.000,287570.000 5109160.000))
OGRFeature(dougIndex):4
PATH (String) = 108.tif
IndexID (Integer) = 108
POLYGON ((288080.000 5109160.000,287570.000 5109160.000,287570.000
5109580.000,288080.000 5109580.000,288080.000 5109160.000))
OGRFeature(dougIndex):5
PATH (String) = 109.tif
IndexID (Integer) = 109
POLYGON ((288590.000 5109160.000,288080.000 5109160.000,288080.000
5109580.000,288590.000 5109580.000,288590.000 5109160.000))
OGRFeature(dougIndex):6
PATH (String) = 110.tif
IndexID (Integer) = 110
POLYGON ((289100.000 5109160.000,288590.000 5109160.000,288590.000
5109580.000,289100.000 5109580.000,289100.000 5109160.000))
==JPEG2000: (command used: '')
INFO: Open of `dougIndex_jp2.shp'
Layer name: dougIndex_jp2
Geometry: Polygon
Feature Count: 7
Extent: (286040.000007, 5109160.000042) - (289100.000009, 5109580.000043)
Layer SRS WKT:
(unknown)
PATH: String (15.0)
OGRFeature(dougIndex_jp2):1
PATH (String) = 105.jp2
OGRFeature(dougIndex_jp2):2
PATH (String) = 106.jp2
OGRFeature(dougIndex_jp2):3
PATH (String) = 107.jp2
OGRFeature(dougIndex_jp2):4
PATH (String) = 108.jp2
OGRFeature(dougIndex_jp2):5
PATH (String) = 109.jp2
OGRFeature(dougIndex_jp2):6
PATH (String) = 110.jp2
I hope I covered all the bases. If you need any more info, sling your
questions my way.
Thank you,
Brant Anderson
Ed McNierney wrote:
> Brant -
> You mentioned "tile", so I assume you're using a TILEINDEX. You
> mention changing the PATH attribute of the shapefile - could you be a
> little more specific? Could you post the LAYER definition in your MAP
> file for this layer? I would expect that you would use gdaltindex to
> create a new TILEINDEX shapefile with the new filenames in it
> (remember that gdaltindex will add to an existing file, so you'll want
> to create a new one). Then you would change the TILEINDEX statement
> in your MAP file to refer to this new shapefile.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: +1 978 251-4242 Fax: +1 978 251-1396
> *From:* UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Brant Anderson
> *Sent:* Thursday, August 26, 2004 1:21 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] JPEG 2000 format instead of TIFF for
> a RASTER layer
> I am trying to tile ortho photos using the JPEG 2000 (jp2) format. I
> have created a working tif version.
> I converted the TIF images to JP2 files using jasper. Then I updated
> the PATH attribute of the shapefile to reflect the new file extension.
> This, however, created unexpected results. I am getting an Internal
> Server Error.
> Here is my MapServer output: (mapserv -v)
> MapServer version 4.2.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7
> INPUT=OGR *INPUT=GDAL* INPUT=SHAPEFILE
> Here is my gdal-config output: (gdal-config --formats)
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem
> jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb *jpeg2000*
> gif jpeg png grass
> Does anybody know if it is possible to use JPEG 2000 instead of TIFF
> for this?
> I would like to use this format if possible, as the file sizes are
> 2-3x smaller than with the .tif, and the quality differences are
> unnoticeable.
> Any help/suggestions welcome.
> Thank you,
> Brant Anderson
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040826/37275317/attachment.html
