Mouseover events {Scanned}
David Horowitz
mapuser at VERYSPEEDY.NET
Tue Aug 31 14:45:27 EDT 2004
I'm getting the tooltip text from an Oracle database with a unique
identifier that matches an identifier from my DBF file (which holds
other information). Thanks for the advice to look at the ImageMap topic
in the Wiki, I'll be sure to check it out.
David
Siki Zoltan wrote:
>Hi,
>It would not be enough to catch the mouseover event. Where do you get
>the tooltip text from? Try to check the ImageMap topic in the Wiki,
>it may help.
>Bye
>Zoltan
>On Fri, 27 Aug 2004, David Horowitz wrote:
>>I am running mapserver with the rosa applet. Is there any way to create
>>a "tooltip" like mouseover event when the mouse passes over points in a
>>certain layer? Any suggestions on how to accomplish this, even if it
>>means switching the user interface away from rosa, would be helpful.
>>Thanks.
