WFS Problems
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Dec 2 11:04:38 EST 2004
I tried downloading your GML and ogrinfo can read it.
Try to change your projection objects. You now have defined that your WFS
client layer is in epsg:4326 but ofcourse your data is in epsg:32632.
Hope this helps.
Best regards,
Bart
> Hi Yewondwossen Assefa,
> dear List members,
> thank you for your answer.
> During the last hours I include your hint with the forced request method:
> "wfs_request_method" "GET"
> and I also found something else on my own:
> I left the port number (8088) in the URL string:
> So, in my case the complet request is called:
> http://babyz.uni-muenster.de:8088/wfs/WFS?
> This might also be the reason why you did not work for you, too!
> When sending above mentioned request the server sends a complete .gml
> file which is stored in my tmp directory.
> Nevertheless still these coordinates are not drawn from the mapserver.
> The beginning of the .gml file sounds like this:
> WLIS_UTM32555409.568178104,5650501.14750786
> 868199.990485413,5934332.6040282555409.5681781038,5934223.853692098
> 555418.5706741122,5934332.604028199
> PEGELSTAND100.0555418.5706741122,5934332.604028199
> 557407.5662599645,5933762.565755668
> PEGELSTAND100.07000000000001557407.5662599645,5933762.565755668
> 559292.2735897198,5933662.819451575
> (... hundreds of coordinate pairs are following!)
> the gml file is stored in the /srv/www/htdocs/tmp directory
> I am running the mapserver vers: 4.2.3 with wms client/server and wfs
> client7server support
> (that it what the mapserver gives back when typing the ./mapserv -v
> command!)
> does anybody have an idea what could still be wrong?
> thanks
> Karsten
> schrieb: One other thing you can try is to force mapserver to send Get
> request to the wfs server by adding the following metadata on your layer
> (default is Post) :
> "wfs_request_method" "GET".
> You should also test the wfs_server by manulally sending some requests
> to make sure that that the wfs responsd properly. Does the
> http://babyz.uni-muenster.de/wfs/WFS?SERVICE=WFS&VERSION=1.0.0&Typename=WLIS_UTM32&&REQUEST=GetFeature
> returns something for you (I does not work for me but It might me an
> internal URL) ?
> Later,
> K. Lessing%
