[UMN_MAPSERVER-USERS] RE : [UMN_MAPSERVER-USERS] 4.4 Windows
Binaries (Oracle, SDE, and others)
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Thu Dec 2 12:20:39 EST 2004
Hi Fernando,
Thanks for your quick answer...
I used the exact same mapfile I used for my previous version of mapserver. It worked fine with this previous version.
Here's the mapserv-v output :
MapServer version 4.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
If I point directly to mapserver on the server I got the normal:
No query information to decode. QUERY_STRING not set.
If I asked for a raster layer, I got it normally.
It's only when I asked for an Oracle layer that I get the error message. (We use Oracle 9.2.0.4 and 10g)
Either the message from my previous post or :
Erreur CGI
L'application CGI spécifiée a mal fonctionné en ne renvoyant pas de jeu complet d'en-têtes HTTP. Les en-têtes renvoyés sont :
Do I have to change something in the mapfile!?
Nicolas
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de FERNANDO SIMON
Envoyé : Thursday, December 02, 2004 10:30 AM
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] RE : [UMN_MAPSERVER-USERS] 4.4 Windows Binaries (Oracle, SDE, and others)
Hi Nicolas,
This message can be when the mapserver can't connect in your database. Try to check your connection string or your Oracle tnsnames.
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
LCA - http://g10.cttmar.univali.br
Quoting "Fortin,Nicolas [SteFoy]" <nicolas.fortin at EC.GC.CA>:
> Now I tested it on my Web Server and I got this message if I call an
> oracle layer ...
> msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI
> Handlers. Connection failure.
> I can't find anything on this error
> Nicolas
Este e-mail foi enviado pelo webmail do curso de
Ciência da Computação - UNIVALI
