Win XP and paths in the .map file
Ed McNierney
ed at TOPOZONE.COM
Thu Dec 2 13:04:22 EST 2004
You are right in thinking that this is probably a permissions problem.
Be sure that the IUSR account has read access to that particular file; I
think permission settings are the most common cause of problems when
migrating from one machine to another "identical" one.
Separately, it might not be the best idea to store your shapefiles in
the wwwroot tree if you want to protect them from being accessed outside
of MapServer. It's usually wise to place MapServer's data files safely
outside any place that grants access to Web users.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Manuel Alonso
Sent: Thursday, December 02, 2004 11:03 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Win XP and paths in the .map file
Good afternoon:
I have been running MapServer 4.2.0 in Windows 2K and that works OK. I
have copied my application to Windows XP SP2 and configured all the
permissions, etc. as I did on Windows 2K, and now it seems that
MapServer is unable to read the paths from in the .map file. The .map
file contents
are:
NAME satgeobase
SHAPEPATH "shapefiles/satgeobase"
UNITS meters
IMAGECOLOR 255 255 255
TRANSPARENT ON
SYMBOLSET symbols/symbols.sym
LAYER
DEBUG on
NAME countries
TYPE polygon
STATUS ON
DATA "cntry98"
CLASS
NAME "Country outline"
COLOR 255 255 255
OUTLINECOLOR 255 255 0
END
END
END
If I type the following line in Internet Explorer:
http://127.0.0.1/mapserver/mapserv.exe?
map=c:\Inetpub\wwwroot\satgeobase.map&mode=map&layer=countries&imgsize=8
00+
400&mapext=-180+90+180+-90
Map Server returns:
msDrawMap(): Image handling error. Failed to draw layer named
'countries'.
msSHPOpenFile(): Unable to access file. (c:\Inetpub\wwwroot\cntry98)
(c:\Inetpub\wwwroot\shapefiles/satgeobase/cntry98)
If I change the SHAPEPATH line to SHAPEPATH "shapefiles\satgeobase\",
then the result is:
'countries'.
(c:\Inetpub\wwwroot\shapefiles\satgeobase\cntry98)
I have tried to use double backslash, double forwardslash and many
combinations, but it seems that MapServer.exe cannot find the shape
files.
The shapefiles exist, names and paths are correct, the default firewall
that XP sets up is disabled, and I have even given administrative rights
to the IUSR_<> user, just in case. I get the same result, the same
answer that MapServer gives when the files do not exist.
Does anyone know if this is a known problem? Any ideas?
Thanks very much in advance,
Manuel
