teacher points on California zips revisited
Joseph Norris sirronj at PACBELL.NET
Thu Dec 2 14:56:10 EST 2004
Can I not do some sort of merge of the two shape files or better yet can I
not open both shape files programmatically and while looking at my
California zip shape file build the teacher shape file in accord with the
California shape file?
Thanks.
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of Eric Bridger
Sent: Thursday, December 02, 2004 10:48 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] teacher points on California zips
revisited
You need UNITS DD in your points layer where proj=latlong, or no UNITS
since DD is probably the default.
On Thu, 2004-12-02 at 13:13, Joseph Norris wrote:
> Ok - here is my map file.  I have set the min/max of the layers so that
when
> I zoom in I should be able to see the teacher points and loose the
"Teachers
> in Zip" coloring - this happens - sort of.  When I zoom in I loose the
color
> and get the teacher circle in the legend but I do not get any polygon
> outline and no circles for the teachers.
> MAP
>   EXTENT 5706290.827754 -192053.2 9127890.404246 3226086.749
>   TEMPLATEPATTERN "map"
>   IMAGECOLOR 255 255 255
>   IMAGETYPE gif
>   SHAPEPATH
"/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/teacher/tdata
>   SIZE 700 700
>   STATUS ON
>   UNITS FEET
>   PROJECTION
>     "init=epsg:26942"
>   END
>   NAME "calmap"
>   OUTPUTFORMAT
>     NAME gif
>     MIMETYPE image/gif
>     DRIVER GD/GIF
>     EXTENSION gif
>     IMAGEMODE PC256
>     TRANSPARENT FALSE
>   END
>   SYMBOL
>     NAME "circle"
>     TYPE ELLIPSE
>     FILLED TRUE
>     POINTS
>       1 1
>     END
>   END
>   LEGEND
>     KEYSIZE 20 10
>     KEYSPACING 5 5
>     LABEL
>       SIZE MEDIUM
>       TYPE BITMAP
>       BUFFER 0
>       COLOR 0 0 0
>       FORCE FALSE
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       OFFSET 0 0
>       PARTIALS TRUE
>       POSITION CC
>     END
>     POSITION LL
>     STATUS EMBED
>   END
>   QUERYMAP
>       COLOR 255 255 0
>     SIZE -1 -1
>     STATUS OFF
>     STYLE HILITE
>   END
>   SCALEBAR
>       COLOR 0 0 0
>     INTERVALS 4
>     LABEL
>       SIZE MEDIUM
>       TYPE BITMAP
>       BUFFER 0
>       COLOR 0 0 0
>       FORCE FALSE
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       OFFSET 0 0
>       PARTIALS TRUE
>     END
>     POSITION LL
>     SIZE 200 3
>     STATUS OFF
>     STYLE 0
>     UNITS MILES
>   END
>   WEB
>     IMAGEPATH ""
>     IMAGEURL ""
>     QUERYFORMAT text/html
>   END
>   LAYER
>     CLASSITEM "zcta"
>     DATA "cal_zp_st"
>     NAME "calzip"
>     SIZEUNITS PIXELS
>     STATUS DEFAULT
>     TOLERANCE 0
>     TOLERANCEUNITS PIXELS
>     MINSCALE 1478131.017053
>     TYPE POLYGON
>     PROJECTION
>      "init=epsg:26942"
>     END
>     UNITS FEET
>     CLASS
>       NAME "Teachers in Zips"
>       EXPRESSION
/95822|94117|93230|94903|91941|94110|95818|95815|91006|92503|90305|90042|953
> 37|95020|90242|94123|92084|94949
|93702|92802|95648|94103|95135|91103|95687|95632|95329|92024|91326|92054|935
> 60|93010|90043|90805|93023|90012|94606|91405|9195
0|90720|93405|94124|91935|95128|95124|94112|92663|92308|94087|92630|92105|94
> 115|94520|90033|94040|94621|92804|95501|91764|939
07|92186|94901|95210|94509|95076|94513|91910|95825|90032|93274|94612|91601|9
> 5351|93960|90025|95608|94952|90405|94105|90241|95
665|94404|92028|92115|92629|92083|92107|92117|92675|93711|38125|92570|94558|
> 93291|93720|95816|92320|95864|94107|94607|94131|9
0018|95125|91789|91101|95118|96001|94710|95032|95570|94121|92507|90262|95139
> |95692|94704|94611|92585|94402|92705|90063|94560|
93727|94549|90015|95993|90274|93901|90065|90232|91977|93212|91730|92127|9239
> 2|92111|93706|95452|94804|91107|91945|92612|94539
|93924|92505|93710|92019|92801|91962|95834|90270|90802|95126|94555|95823|943
> 03|92108|92128|95690|92064|92071|92120|92025|9310
9|94580|94904|91406|94108|94070|74580|93034|90066|92509|94401|90059|95562|94
> 947|95242|91911|95521|93111|95658|94122|94102|907
45|95050|93449|95060|93446|93726|95969|95110|91104|91001|90049|95838|94577|9
> 2131|92040|95204|94545|91932|95018|91411|92106|94
568|95304|95407|94531|95678|90292|92243|91711|92410|95070|93004|92008|95829|
> 93908|93721|94703|94954|95959|94134|95428|90003|9
1384|93591|94304|94501|94133|95670|95814|95127|93012|94591|92121|90220|94806
> |92591|95531|90504|94705|94530|95376|93003|94707|
> 95841|95667/
>       STYLE
>           COLOR 255 102 102
>         MAXSIZE 100
>         MINSIZE 1
>         SIZE 1
>         SYMBOL 0
>       END
>     END
>     CLASS
>       NAME "Zip Boundries"
>       EXPRESSION /./
>       STYLE
>         MAXSIZE 100
>         MINSIZE 1
>           OUTLINECOLOR 204 204 204
>         SIZE 1
>         SYMBOL 0
>       END
>     END
>   END
>   LAYER
>     NAME "points"
>     SIZEUNITS PIXELS
>     STATUS DEFAULT
>     TEMPLATE "bogus.html"
>     TOLERANCE 10
>     TYPE POINT
>     UNITS FEET
>     MAXSCALE 1478131.017053
>     PROJECTION
>         "proj=latlong"
>     END
>     CLASS
>       NAME "Teachers"
>       LABEL
>         SIZE MEDIUM
>         TYPE BITMAP
>         BUFFER 2
>         COLOR 255 0 0
>         FORCE FALSE
>         MINDISTANCE -1
>         MINFEATURESIZE -1
>         OFFSET 0 0
>         PARTIALS FALSE
>         POSITION AUTO
>       END
>       STYLE
>         COLOR 255 255 0
>         OUTLINECOLOR 0 0 0
>         SIZE 8
>         SYMBOL "circle"
>       END
>     END
>     FEATURE
>       POINTS
>         38.5263 -121.507
>       END
> List of points for lat/long with text of teacher's names
chr
> Behalf Of David Fawcett
> Sent: Thursday, December 02, 2004 9:20 AM
> revisited
> In addition to what Ethan says,
> For your teachers layer, you could use the below projection block in
> place of projection=latlong (this is just the EPSG code for latlong):
>  PROJECTION
>      "init=epsg:4267"
>  END
> David J. Fawcett
> MN Office of Environmental Assistance
> >>> Ethan Alpert <ealpert at DIGITALGLOBE.COM> 12/2/2004 11:10:22 AM >>>
> Go back and read the answers to your previous posts. What your
> PROJECTION blocks should be was already discussed.
> -e
> On
> Behalf Of Joseph Norris
> Sent: Thursday, December 02, 2004 10:08 AM
> revisited
> Thanks for this information - so do I have to take my point file and
> create it within the state plane also?  I so how will I do that build?
> @c=map
> chr
> 14,-
> Behalf Of Ethan Alpert
> Sent: Thursday, December 02, 2004 9:01 AM
> revisited
> Those are meters not lat/lon and are probably in the California state
> plane projection. You posted the .prj previously which clearly showed
> that you data was in the state plane projection.
> -e
> On
> Sent: Thursday, December 02, 2004 9:55 AM
> Subject: [UMN_MAPSERVER-USERS] teacher points on California zips
> revisited
> Hello,
> Here we go again.  I finally did the following:
> Created a shape file of all of my teacher points by their lat/long.
> Dropped the California zip code map on to my laptop and then the new
> teacher points file. I then used fGIS
> (http://www.digitalgrove.net/fgis.htm)  and loaded the California zip
> layer and then my new teacher point layer. I can zoom to the zip layer
> but when I zoom to the point layer it is way far away from the zip
> layer.  I did this as a sanity check because I did not think that I
> was
> even producing the teacher point layer.  The questions are:
> If I create a point shape file based upon lat/lon and I have the
> California zip file - why will one not lie over the other - are they
> not
> both based upon lat/long?
> Can I open my teacher dbf file, and go search for the zip in the
> California zip file and then rebuild the teacher point file with
> coordinates from the California zip file thus allowing me to place my
> points in the zip polygon that they belong to?
> In my California shape file on a dump I get:
>      ( 5983045.379, 3224996.563, 0, 0)
>      ( 5989542.292, 3224832.974, 0, 0)
>      ( 5989921.623, 3224823.475, 0, 0)
>      ( 5989953.049, 3224815.898, 0, 0)
>      ( 5990112.487, 3224777.458, 0, 0)
>      ( 5991452.255, 3224753.633, 0, 0)
>      ( 5993483.853, 3224717.643, 0, 0)
>      ( 5993800.929, 3224702.331, 0, 0)
>      ( 6011910.153, 3224087.577, 0, 0)
>      ( 6017051.977, 3223915.448, 0, 0)
>      ( 6026300.989, 3223711.249, 0, 0)
>      ( 6026888.615, 3222812.493, 0, 0)
> What do these values mean - are they lat/long values?
> Thanks for all of the help that you have given me so far.
> @c=map
> chr
> 14,-
