IMAGETYPE
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Thu Dec 2 19:50:12 EST 2004
Nasir,
You haven't actually specified an output format in your mapfile. Look at:
http://mapserver.gis.umn.edu/doc42/mapfile-reference.html#outputformat
You must have an output format in there with a name that matches your imagetype. Your outputformat contain the instructions on what kind of image to create for that imagetype. Once your put the outputformat object in there (can be more than 1), your imagetype should work.
It probably works when you commented it out because mapserver uses a default imagetype if it cannot find any output format object in the mapfile.
regards,
Jacob
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of nasir mahmood
Sent: 3 December 2004 06:42
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] IMAGETYPE
I am trying to understand mapserver's tutorial examples. I am facing a problem with IMAGETYPE tag. when I set IMAGETYPE PNG, map isn't displayed but when I comment it out then it 's ok. Why it is so? Here is map files:
MAP
#IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "C:\Program Files\Apache Group\Apache2\htdocs\tutorial\data\"
IMAGECOLOR 255 255 255
PROJECTION
"proj=laea"
ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END # end of map file/object
Nasir
Do you Yahoo!?
Yahoo! Mail - Easier than ever with enhanced search. Learn more.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041203/005147f2/attachment.html
