Given map extent is invalid
nasir mahmood nasir_pcit at YAHOO.COM
Fri Dec 3 19:13:00 EST 2004
I have gone through this problem. The way I solved this problem is:
1 - download Fwtools from http://fwtools.maptools.org/
2 - then you ogrinfo command to find extent of you shape file and then you that extent in you map file.
           command: ogrinfo -al -so myfile.shp
regards,
nasir
Dan Liu <Dan.Liu at STATE.MN.US> wrote:
PHP mapscript application which worked in mapserv 4.2.5 now gives the error 'Given map extent is invalid.' after function 'ms_newMapObj()' is called. The extent is
EXTENT 118109 5269319 792271 4997508
Does anybody know want is wrong? Any help is appreciated.
Dan
Do you Yahoo!?
 Read only the mail you want - Yahoo! Mail SpamGuard.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041203/855263db/attachment.html
