php mapscript persistance across requests
Paul Spencer pspencer at DMSOLUTIONS.CA
Sun Dec 5 18:11:20 EST 2004
John,
here's three different approaches you might consider using
1. hidden HTML inputs
2. session variables
3. saving the entire map file
You will probably need to use a combination of these ... each one is
only an example, you'll need to do some work to figure out how to use it
in your setup ...
Cheers
Paul
1. Hidden HTML variables
<?php
if (isset($_REQUEST['extents']) && $_REQUEST['extents'] != '')
     $aExtents = explode( ',', $_REQUEST['extents'] );
     if (count($aExtents) == 4)
         $oMap->extents->setextent( $aExtents[0], $aExtents[1],
                                    $aExtents[2], $aExtents[3] );
//some processing
<input type="hidden" name="extents" value="<?php echo implode( ",",
$oMap->extents)?>">
use the same approach (html hidden variables) for all other information
2. Session variables
<?php
if (isset($_SESSION['extents']) && $_SESSION['extents'] != '')
     $oMap->extents->setextent( $_SESSION['extents'][0],
                                $_SESSION['extents'][1],
                                $_SESSION['extents'][2],
                                $_SESSION['extents'][3] );
//some processing
$_SESSION['extents'] = $oMap->extents;
and use the same approach for all other information
3. Save map file ...
<?php
if (isset( $_SESSION['previousState'] ))
     $oMap = ms_newMapObj( $_SESSION['previousState'],
                           $_SESSION['originalLocation'] );
//some processing
$oMap->save( $tempFile );
$_SESSION['previousState'] = $tempFile;
Jon Saints wrote:
> I Am new to php mapscript. Is there any standard way
> of storing map extent and layer information across
> http requests in phpmapscript?
> I realize that storing the map object in the session
> is not possible.  What are my other options?
> Thanks
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
