raster not showing
didier.georgieff
didier.georgieff at AGRICULTURE.GOUV.FR
Tue Dec 7 12:11:35 EST 2004
Dear Ethan,
Thanks for your response. In fact i sent the message too early by
mistake. A detailed one follows.
Le mar 07/12/2004 à 17:57, Ethan Alpert a écrit :
> Unfortunately MS gives you plenty of rope to hang yourself. When things
> don't show up it is usually a misconfiguration in the mapfile.
I tried to have exactly the same itasca syntax.
> If you
> get the mapfile syntax wrong you'll get an error but if you get
> something like PROJECTION,UNITS, etc wrong you get nothing.
I guess it's my case.
> The first step in debugging why a raster doesn't show up is to make sure
> you know what it's projection is and make sure your map file represents
> it.
Projections are the same for the shape files and the TIFFs. And i give
no projections at all in the map file.
Should I do ?
> The Raster Data how-to actually has some nuggets in it:
> http://mapserver.gis.umn.edu/doc42/raster-howto.html
Thanks. I read it this afternoon. No luck since.
> When this happens to me I try to display each layer separately to make
> sure that part works then put them into a single map file. You can use
> the mapserver CGI in mode=map map to quickly and easily load mapfiles
> with different layers and see if they work or don't. The key is to come
> up with ways you can diagnose your problem.
Yes. I tried but couldn't find a simple CGI URL for just display the
TIFF. I'll try to look deeper.
> Just keep in mind that it is
> very rarely an actual bug (especially if you're just getting started)
Oh yes. I realy don't suspect a bug. I can witness on my dumbness ;-))
Thanks a lot for your response.
D.
