raster not showing
didier.georgieff didier.georgieff at AGRICULTURE.GOUV.FR
Wed Dec 8 04:24:33 EST 2004
Le mar 07/12/2004 à 19:16, Ethan Alpert a écrit :
> This is very simple and something I use over and over to find my errors.
> Here's an example I just did. In my home directory I wrote a mapfile
> with just one raster layer:
> Then I called mapserv with the following URL:
> http://localhost/cgi-bin/mapserv?map=/home/ealpert/test.map&mode=map
Thanks A LOT !! This what I needed.
And this allowed me to confirm that the raster alone was not showing up.
The problem's origin was in folder persmissions (chmod o+w solved the problem !)
Thanks again for the tip.
For MS developpers, just one small note related to that : even with --enable-debug i had no error
message on the browser or in the Apache log.
May be a log warning "can't access the raster file" would be of some help. I think i remember that this
kind of problem on shp files produces an error output (my memory can be wrong)
So thanks for the help, and thanks to MS developpers for such a beast !
D.
