PDF Output
Andrew Seales
andrew.seales at ED.AC.UK
Wed Dec 8 09:52:36 EST 2004
I seem to be having trouble outputting data from a WMS Server in PDF format.
When I call GetCapabilities, application/x-pdf doesn't appear as an image
format in the <GetMap>, <Format> tags.
PDF support is compiled in using PDFLib 5.04, and mapserv -v returns:
MapServer version 4.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WFS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
At the top of the capabilities file, the comments below <WMT_MS_Capabilities
version="1.1.1"> also indicate that PDF support is compiled in.
These are the OUTPUTFORMAT lines in the map file:
OUTPUTFORMAT
NAME pdf
DRIVER "pdf"
MIMETYPE "application/x-pdf"
IMAGEMODE RGB
EXTENSION "pdf"
END
The type of data being drawn is vector data, and I am using Solaris 8.
Anyone got any ideas?
Thanks,
Andrew Seales
