PDF Output
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Dec 8 11:10:28 EST 2004
The 4.4 release only supports GD and GDAL formats for WMS. This is
described in bug 455
(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=455). The next
release will have a mechanism (not yet decided) where the user can
specify the additional formats that he wants to publish in the capablities.
Later,
Andrew Seales wrote:
> I seem to be having trouble outputting data from a WMS Server in PDF format.
> When I call GetCapabilities, application/x-pdf doesn't appear as an image
> format in the <GetMap>, <Format> tags.
> PDF support is compiled in using PDFLib 5.04, and mapserv -v returns:
> MapServer version 4.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WFS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> At the top of the capabilities file, the comments below <WMT_MS_Capabilities
> version="1.1.1"> also indicate that PDF support is compiled in.
> These are the OUTPUTFORMAT lines in the map file:
> OUTPUTFORMAT
> NAME pdf
> DRIVER "pdf"
> MIMETYPE "application/x-pdf"
> IMAGEMODE RGB
> EXTENSION "pdf"
> END
> The type of data being drawn is vector data, and I am using Solaris 8.
> Anyone got any ideas?
> Thanks,
> Andrew Seales
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
