simple tool for conversion
Jon Saints
saintsjd at YAHOO.COM
Wed Dec 8 14:27:03 EST 2004
Hi
I have a Mr Sid raster i would like to display in
mapserver. What is the best way to do that? should i
convert to another format?
Thanks
--- Ed McNierney <ed at TOPOZONE.COM> wrote:
> Joseph -
> Sorry, but I don't know what fGIS is, so I'll be a
> little vague, but if
> you're using multiple data sources in different
> projections then you
> need to (a) be using software that can handle layers
> in different
> projections and (b) accurately describe what
> projection each of your
> layers is using.
> If you can't do that, then you will need to
> reproject your lat/lon data,
> but if that's the case it's a limitation of the
> software or the user,
> not a limitation of shapefiles.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Joseph Norris [mailto:sirronj at pacbell.net]
> Sent: Wednesday, December 08, 2004 11:54 AM
> To: Ed McNierney; MAPSERVER-USERS at lists.umn.edu
> Subject: RE: [UMN_MAPSERVER-USERS] simple tool for
> conversion
> Well - here is my experience:
> I did just that - wrote a script that built a
> shapefile using the
> lat/long coordiance. My shape file looked like this
> on a dump:
> File Bounds: ( 32.586, -124.206,0,0)
> to ( 41.773, -89.769,0,0)
> Shape:0 (Point) nVertices=1, nParts=0
> Bounds:( 38.526, -121.507, 0, 0)
> to ( 38.526, -121.507, 0, 0)
> Shape:1 (Point) nVertices=1, nParts=0
> Bounds:( 37.775, -122.451, 0, 0)
> to ( 37.775, -122.451, 0, 0)
> Then I went and used fGIS and plotted some points on
> a layer over my
> California map and I got the following:
> File Bounds: ( 6471392.899, 282843.628,0,0)
> to ( 8433025.828, 2304680.124,0,0)
> Bounds:( 7750718.722, 1391592.674, 0, 0)
> to ( 7750718.722, 1391592.674, 0, 0)
> Bounds:( 6471392.899, 2304680.124, 0, 0)
> to ( 6471392.899, 2304680.124, 0, 0)
> Shape:2 (Point) nVertices=1, nParts=0
> Bounds:( 8433025.828, 282843.628, 0, 0)
> to ( 8433025.828, 282843.628, 0, 0)
> There is a big difference which led me to believe
> that I needed to
> convert lat/long to x/y coordinates.
> #Joseph Norris (Perl - what else is
> there?/Linux/CGI/Mysql) print @c=map
> chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,
> 14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at lists.umn.edu]On
> Behalf Of Ed McNierney
> Sent: Wednesday, December 08, 2004 8:46 AM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] simple tool for
> conversion
> Joseph -
> You should realize that there's nothing wrong with
> putting lat/lon
> coordinates in a shapefile. You seem to think that
> some "conversion" is
> necessary, and it's not. The world is full of
> shapefiles with lat/lon
> coordinates in them.
> - Ed
> Ed McNierney
> ed at topozone.com
> (978) 251-4242
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Joseph Norris
> Sent: Wednesday, December 08, 2004 11:37 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> conversion
> Yes that is what I am trying to do. I have the
> latitude and longitude
> for different Mysql database records and I wish to
> produce a point shape
> file of these coordinates.
> chr
> 14,-
> From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
> Sent: Wednesday, December 08, 2004 8:28 AM
> To: Joseph Norris; MAPSERVER-USERS at lists.umn.edu
> conversion
> This makes no sense to me what-so-ever what are you
> trying to do? Take
> vertices in a text file and build a shapefile?
> Project lat/lon values
> into California State Plane?
> -e
> [mailto:MAPSERVER-USERS at lists.umn.edu] On
> Sent: Wednesday, December 08, 2004 7:58 AM
> Subject: [UMN_MAPSERVER-USERS] simple tool for
> conversion
> Can anyone make a recommendation for unix command
> line tool that will
> convert lat/long to xy coordinates?
> Thanks.
> chr
> 14,-
