Mr SID in mapserver
Jon Saints saintsjd at YAHOO.COM
Wed Dec 8 14:47:42 EST 2004
What is the best way to convert MrSID to GeoTiff?
is there a way to do it on linux?
Thanks
Jon
--- Frank Warmerdam <fwarmerdam at gmail.com> wrote:
> On Wed, 8 Dec 2004 11:28:20 -0800, Jon Saints
> <saintsjd at yahoo.com> wrote:
> > Hi
> > I have a Mr Sid raster i would like to display in
> > mapserver. What is the best way to do that? should
> i
> > convert to another format?
> Jon,
> It is possible to download the MrSID SDK from
> Lizardtech
> and then build a GDAL using it, and then build
> MapServer
> using that GDAL.  But that is a somewhat complex
> process.
> If you don't particularly need to serve directly
> from the MrSID
> files, I would suggest just converting to GeoTIFF
> and using
> that.  Most existing binaries should support GeoTIFF
> directly.
> Best regards,
> I set the clouds in motion - turn up   | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
