simple tool for conversion
Joseph Norris
sirronj at PACBELL.NET
Wed Dec 8 18:40:34 EST 2004
I do the following:
[joseph at spare:]$ proj +units=us-ft +init=nad83:4202 <<EOD
> -119.770623
> 36.830072
> EOD
-7049825.31 -4677803.10
45036164.88 26747054.17
I am not sure what the results are. Are these x/y coordinates? And if so -
which set the upper or the lower.
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of Lawrence, Kevin
Sent: Wednesday, December 08, 2004 7:05 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] simple tool for conversion
proj - the same utility used for on the fly re-projection
one example
echo $lat $long | proj +proj=lcc +lon_0=95w +lat_0=0 +lat_1=49 +lat2=77 -r
project geographic to
lambert conformal
origin -95 0
1st parallel 49
2nd parallel 77
KL
> From: UMN MapServer Users List[SMTP:MAPSERVER-USERS at LISTS.UMN.EDU]
> on behalf of Joseph Norris[SMTP:sirronj at PACBELL.NET]
> Reply To: Joseph Norris
> Sent: Wednesday, December 08, 2004 9:58 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] simple tool for conversion
> Can anyone make a recommendation for unix command line tool that will
> convert lat/long to xy coordinates?
> Thanks.
> chr
