datapattern and OGR connectiontype and MORE
Javier Castillejo Montes
jcastil1 at TRAGSA.ES
Thu Dec 9 06:53:21 EST 2004
Hi there,
I'm wondering if there is any methos related or notr with DATAPATTER that
allow to chande the "DATA".
Tyler Mitchell wrote one year ago "Can the datapattern method be used for
other data sources than simple shape
file references (i.e. used in the sql for a postgis layer?)."
I've been seraching the archives with not results...my question is just
that .
I'm using mapserv4.2 IIS php OracleSpatia on Oralce8.1.7
I would like to change the DATA 'cos I have to select the data depending on
some parameters from the users. I've tried with "DATAPATTERN ".*" (and all
it's different ways) + "map_layername_data" but no results, no errors and
the DATA comes from the mapfile definition!!!
It works find with shp+bdf files!!!!
It works find with CONNECTIONTYPE oraclespatial!!!! (but I will have
problems when query the map--> "msOracleSpatialLayerGetShape():
OracleSpatial error. Function not implemented yet")
It fails with CONNECTIONTYPE OGR
here is an mapfile scratch:
MAP
NAME Frames_
IMAGETYPE png24
SIZE 800 600
EXTENT -450000 3800000 1200000 4870000
SHAPEPATH "../data/"
SYMBOLSET "../symbols/symbols35.sym"
FONTSET "../fonts/fonts.list"
UNITS METERS
DATAPATTERN ".*"
LAYER # Autonomias
NAME autonomias
STATUS DEFAULT
TYPE POLYGON
GROUP NOLEYENDA
CONNECTIONTYPE OGR
CONNECTION "OCI:XXX/XXXXX at XXX"
DATA "SELECT * FROM AUTONOMIAS_vw"
Any Idea?
Other question:
Does any one know why :
DATA "GEOMETRY FROM (SELECT * FROM AUTONOMIAS_VW WHERE BUSINESS like DECODE ('%Business%','TantoPorCiento','%','%Business%') AND EMERGENCIA like DECODE ('%Emerg%','TantoPorCiento','%','%Emerg%') AND LINEGO like DECODE('% Linego%','TantoPorCiento','%','%Linego%'))"
retuns no data when the data on business, emergencia, lineo is different to "TantoPorCiento", I mean, if a change any values of business, emergencia, lineo there is no data returned but If I try the same query on the SQL_Plus... the data exits
I'm trying to know the "DATA" query that mapserver send to oracle. I'm trying whit DEBUG, but I have not a clear idea of how to use it
Thanks in advance
