Segfault under Mapscript/Perl - Mapserver 4.4.0
Aaron Craig
mercutio at POBOX.COM
Thu Dec 9 11:25:38 EST 2004
Never mind. Removing /usr/lib/libmap.a fixed the problem. I believe I put it there by hand some time ago :S
Aaron Craig wrote:
> I'm getting a segmentation fault when I ask for a layer's name under
> Perl.
> The following script (make sure you've got mapscript.pm installed, copy
> the text into a file, chmod 0755 the file and run it off the command
> line) demonstrates the error.
> I've done a fresh build/install of mapserver 4.4.0 and the perl module
> in mapscript/perl inside the 4.4.0 tarball.
> Any insight would be appreciated.
Aaron Craig
mercutio at pobox.com
Get Firefox!
http://www.spreadfirefox.com/?q=affiliates&id=0&t=1
