simple tool for conversion
Joseph Norris
sirronj at PACBELL.NET
Fri Dec 10 02:35:46 EST 2004
Eric,
I have one question now that all of my points are showing via lon/lat I have
one other question.
I have tried to put features in but they will not show. Can I not do
something like
Feature
Points mylon mylat end
Text " my text "
End
And it should show up on the map?
Thanks.
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
Sent: Thursday, December 09, 2004 2:04 PM
To: Joseph Norris
Cc: UMN MapServerList
Subject: RE: [UMN_MAPSERVER-USERS] simple tool for conversion
On Thu, 2004-12-09 at 16:17, Joseph Norris wrote:
> Eric,
> Thank you for this information. If I have to switch shapefiles to get
this
> to work - then I am all for it. So as I understand you,
> I have obtained the California state map as you indicated on your link.
> Does this mean that I can build my teacher shape file using the actual
> lat/long that I have and then I would be closer to my new California state
> map knowing about my new teacher shapefile?
Yes. These are zipcode polygons with no projection, in latitude
longitude.
You can use: mapserver-N.N.N/mapscript/perl/examples/shpinfo.pl
-file=zt06_d00 to find the extents and the field names in the DBF.
