Warning:[MapServer Error]: msLoadMap():
Christian Reyes A. christian.reyes at UTEM.CL
Fri Dec 10 14:59:56 EST 2004
Hi Ethan:
        First, thaks for your response.
        Yeah, the files are view for apache process, will be neccesary re-compile mapserv with the curl libraries ?? I think the problem is not apache or php else mapserver compiling options, any idea?
        Thanks
        Regards Christian Reyes
  ----- Original Message -----
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Sent: Thursday, December 09, 2004 9:19 PM
  Subject: Re: [UMN_MAPSERVER-USERS] Warning:[MapServer Error]: msLoadMap():
  Did you check the permissions of /var/www/html/mapserver/datos.map?
  Can it be read by your httpd instance?
    -----Original Message-----
    From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Christian Reyes A.
    Sent: Thursday, December 09, 2004 4:16 PM
    Subject: [UMN_MAPSERVER-USERS] Warning:[MapServer Error]: msLoadMap():
    Hi Map Server Users
    Just download and install all software to run mapserv and mapscript, but when point my browser to test PHP script receive the next messages:
    Warning:[MapServer Error]: msLoadMap(): in /var/www/html/mapserver/test.php on line 19
    Warning: Failed to open map file /var/www/html/mapserver/datos.map in /var/www/html/mapserver/test.php on line 19
    Fatal error: Call to a member function on a non-object in /var/www/html/mapserver/test.php on line 46
     I tried with many configurations, modify path (relative, direct, etc) always receive same messages
    Version of installed software are next:
    RedHat 9.0
    Apache 2.0.40-21
    PHP 4.2.2
    Mapserver 4.4.0
    PROJ.4.3.3
    GDAL 1.2.5
    pdflib 6.0.1
    gd-2.0.33
    libtiff 3.5.7-11
    libjpeg 6b-26
    libpng 1.2.2
    zlib-1.1.4-8
    xerces 1_6_0
    parameter for compiling mapserver:
    --with-freetype=/usr --with-zlib=/usr --with-png=/usr --with-jpeg=/usr --with-pdf --with-eppl --with-proj=/usr --with-sde=no --with-geos=no --with-mpatrol=no --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config --with-tiff=/usr --with-php=/usr/local/php-4.2.2 --with-php-regex --with-proj=no --with-curl=no --enable-debug --with-wms=no --with-wfs=no --with-wcs=no --with-wmsclient=no --with-wfsclient=no
    No mayor compiling warningsr, only variables declared but not used
    I'm stuck , anybody can help to resolve this problem ( if solution is not a problem !!!)
    Thanks
    PD: Sorry for my English, i hope your understand
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041210/127de391/attachment.html
