Fw: [UMN_MAPSERVER-USERS] Warning:[MapServer Error]: msLoadMap():
Christian Reyes A.
christian.reyes at UTEM.CL
Mon Dec 13 14:22:18 EST 2004
MessageHi Ethan:
Look, I follow your advise and "off corse" you're in the correct my map file is in the wrong format (Uhhn), sorry for waste your time.
Thanks a lot
Regards Christian
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Friday, December 10, 2004 5:14 PM
Subject: Re: [UMN_MAPSERVER-USERS] Warning:[MapServer Error]: msLoadMap():
If apache can read the file then ther must be an error in the mapfile. I don't think libcurl has anything to do with it.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Christian Reyes A.
Sent: Friday, December 10, 2004 1:00 PM
Subject: [UMN_MAPSERVER-USERS] Warning:[MapServer Error]: msLoadMap():
Hi Ethan:
First, thaks for your response.
Yeah, the files are view for apache process, will be neccesary re-compile mapserv with the curl libraries ?? I think the problem is not apache or php else mapserver compiling options, any idea?
Thanks
Regards Christian Reyes
Sent: Thursday, December 09, 2004 9:19 PM
Did you check the permissions of /var/www/html/mapserver/datos.map?
Can it be read by your httpd instance?
Sent: Thursday, December 09, 2004 4:16 PM
Hi Map Server Users
Just download and install all software to run mapserv and mapscript, but when point my browser to test PHP script receive the next messages:
Warning:[MapServer Error]: msLoadMap(): in /var/www/html/mapserver/test.php on line 19
Warning: Failed to open map file /var/www/html/mapserver/datos.map in /var/www/html/mapserver/test.php on line 19
Fatal error: Call to a member function on a non-object in /var/www/html/mapserver/test.php on line 46
I tried with many configurations, modify path (relative, direct, etc) always receive same messages
Version of installed software are next:
RedHat 9.0
Apache 2.0.40-21
PHP 4.2.2
Mapserver 4.4.0
PROJ.4.3.3
GDAL 1.2.5
pdflib 6.0.1
gd-2.0.33
libtiff 3.5.7-11
libjpeg 6b-26
libpng 1.2.2
zlib-1.1.4-8
xerces 1_6_0
parameter for compiling mapserver:
--with-freetype=/usr --with-zlib=/usr --with-png=/usr --with-jpeg=/usr --with-pdf --with-eppl --with-proj=/usr --with-sde=no --with-geos=no --with-mpatrol=no --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config --with-tiff=/usr --with-php=/usr/local/php-4.2.2 --with-php-regex --with-proj=no --with-curl=no --enable-debug --with-wms=no --with-wfs=no --with-wcs=no --with-wmsclient=no --with-wfsclient=no
No mayor compiling warningsr, only variables declared but not used
I'm stuck , anybody can help to resolve this problem ( if solution is not a problem !!!)
Thanks
PD: Sorry for my English, i hope your understand
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041213/4b9440d5/attachment.html
