Negative values in extent
Daryl Herzmann
akrherz at IASTATE.EDU
Tue Dec 14 09:48:40 EST 2004
Hello,
On Tue, 14 Dec 2004, [ISO-8859-2] Miroslav ?ulc wrote:
>Hi,
>I have upgraded to mapserver 4.4.0 and I am having problem with negative
>values in EXTENT in MAP file. I have maps in S-JTSK (Czech norm) and
>this is a system with negative values. Here is my EXTENT:
>EXTENT -747200 -1043200 -747000 -1046000
>These worked for me when I used the mapserver script. But I cannot make
>them work throught the php mapscript. Thought I finally "succeeded"
>(they appear in the $map->extent till next method is called) to get the
>negative extent to the map object, I still get error that the map cannot
>be drawn.
>Info: object(ms_rect_obj)#46 (5) { ["_handle_"]=> resource(361) of type
>(Unknown) ["minx"]=> int(-747200) ["miny"]=> int(-1043200) ["maxx"]=>
>int(-747000) ["maxy"]=> int(-1046000) }
>*Warning*: [MapServer Error]: msDrawMap(): Unable to initialize image.
>in
>*/var/www/intranet.centaur.startnet.cz/htdocs/modules/maps/CMap.cls.php*
>on line *106*
>*Warning*: [MapServer Error]: msCalculateScale(): Invalid image extent,
>minx=-1.000000, miny=-1.000000, maxx=-1.000000, maxy=-1.000000. in
>on line *106*
>Here is my code (it's copied from the hello example):
> $map = ms_newMapObj($this->m_Row['MapFilePath']);
> $extent = ms_newRectObj();
> $extent->minx = -747200;
> $extent->miny = -1043200;
> $extent->maxx = -747000;
> $extent->maxy = -1046000;
> $map->extent = $extent;
> $image = $map->draw();
> $map_file = $image->saveWebImage();
>Does Mapserver support negative values in extent? If not, is there any
>workaround? I will appreciate any suggestion.
$extent->maxy needs to be greater than $extent->miny . Try switching
them around and it should work...
HTH,
daryl
* Daryl Herzmann (akrherz at iastate.edu)
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
