PHP/MapScript processQueryTemplate Help
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Tue Dec 14 12:00:34 EST 2004
Rene Teniere wrote:
> Hi,
> Just trying to get info functionality working in our site using
> PHP/Mapscript. It seems to get stalled while processing the template. Am
> I doing this wrong?
Which version of MapServer are you using? There was bug 569 that was
fixed in v4.2 (quite a while ago) that was causing problems if you had
TEMPLATE set only at the layer level and not inside classes like you
have done. If you are using a version older than 4.2.0 then you should
either upgrade or try adding the TEMPLATE inside the CLASS as well.
Other than that, I can't see what's wrong based on the information that
you provided. If you are using version 4.4 and the problem persists then
you could maybe file a bug with a small testcase to reproduce.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
